주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Visual Land Prestige 7G Backlight Replacement
필요한 것
  1. Visual Land Prestige 7G Backlight Replacement, Backplate: 1 단계, 이미지 2개 중 1개 Visual Land Prestige 7G Backlight Replacement, Backplate: 1 단계, 이미지 2개 중 2개
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
    댓글 쓰기
  2. Visual Land Prestige 7G Backlight Replacement: 2 단계, 이미지 1개 중 1개
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
    댓글 쓰기
  3. Visual Land Prestige 7G Backlight Replacement: 3 단계, 이미지 2개 중 1개 Visual Land Prestige 7G Backlight Replacement: 3 단계, 이미지 2개 중 2개
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
    댓글 쓰기
  4. Visual Land Prestige 7G Backlight Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 Visual Land Prestige 7G Backlight Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 Visual Land Prestige 7G Backlight Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Lay the device on its back.
    • Flip up the black locking flap then remove the ribbon cables.
    댓글 쓰기
  5. Visual Land Prestige 7G Backlight Replacement: 5 단계, 이미지 3개 중 1개 Visual Land Prestige 7G Backlight Replacement: 5 단계, 이미지 3개 중 2개 Visual Land Prestige 7G Backlight Replacement: 5 단계, 이미지 3개 중 3개
    • Connected to the motherboard there will be a red, black, and grey wire.
    • Use a soldering iron to melt the soldered contact points.
    • Disconnect the wires.
    • Lift the motherboard up and out of the chassis.
    • The high temperatures of a soldering gun and melted solder may create the potential for burns. Inhaling the fumes in an enclosed environment may also lead to irritation and desensitization of the eyes and respiratory tract.
    댓글 쓰기
  6. Visual Land Prestige 7G Backlight Replacement, Backlight: 6 단계, 이미지 1개 중 1개
    • Remove the four screws with a Phillips #000 screwdriver.
    댓글 쓰기
  7. Visual Land Prestige 7G Backlight Replacement: 7 단계, 이미지 2개 중 1개 Visual Land Prestige 7G Backlight Replacement: 7 단계, 이미지 2개 중 2개
    • Use an opening tool to lift the backplate out of the case.
    • Pay close attention to the black tabs holding it in, making sure not to break them.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Anna Anderson
회원 가입일: 09/14/23
380 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 267
