이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to replace the LCD display if the screen breaks. Soldering and de-soldering will be necessary.
필요한 것
Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
Remove the three 4.0mm screws holding down the circuit board with the Phillips #00 screwdriver.
Desolder the black wire from the LCD.
For soldering information, see our guide: How To Solder and Desolder Connections.
다른 한 분이 해당 안내서를 완성하였습니다.
