주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vivitar DVR 781HD Battery Replacement
필요한 것
    1. Vivitar DVR 781HD Battery Replacement, Front Case: 1 단계, 이미지 3개 중 1개 Vivitar DVR 781HD Battery Replacement, Front Case: 1 단계, 이미지 3개 중 2개 Vivitar DVR 781HD Battery Replacement, Front Case: 1 단계, 이미지 3개 중 3개
      • Begin with the camcorder lens up on a clear working surface.
      • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
      댓글 쓰기
    2. Vivitar DVR 781HD Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
      댓글 쓰기
    3. Vivitar DVR 781HD Battery Replacement: 3 단계, 이미지 3개 중 1개 Vivitar DVR 781HD Battery Replacement: 3 단계, 이미지 3개 중 2개 Vivitar DVR 781HD Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
      • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
      댓글 쓰기
    1. Vivitar DVR 781HD Battery Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Vivitar DVR 781HD Battery Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
      • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
      댓글 쓰기
    2. Vivitar DVR 781HD Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Gently lift the motherboard, handling it by the edges.
      댓글 쓰기
    1. Vivitar DVR 781HD Battery Replacement, Battery: 6 단계, 이미지 2개 중 1개 Vivitar DVR 781HD Battery Replacement, Battery: 6 단계, 이미지 2개 중 2개
      • The battery connections are reinforced by black potting compound. Gently pry it away with a plastic spudger.
      • Be very careful with this step, as applying too much force can damage the motherboard or the components on it.
      댓글 쓰기
    2. Vivitar DVR 781HD Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Melt the soldered battery connections with a soldering iron and gently pull the battery wires away.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nathan McDaniel
회원 가입일: 02/13/16
592 평판
안내서 3개를 작성함
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016 회원
IUPUI-WILSON-S16S54G6
3 회원들
안내서 13개를 작성함
2가이드 댓글
Where can I get a battery
Albert Einstein - 답글 공유
Any 3.7v Lithium Ion cell will work, truth be told, but if you google the writing you find on the factory battery once you open it, you will likely find dozens of vendors on ebay, amazon, alibaba, wish, etc. personally, i removed the battery and ran leads from the factory battery wires to an external battery pack that holds an 18650 cell which significantly increased available maH
undwirtanzten - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 41
전체 시간: 7,229
