주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vivitar DVR 781HD Screen Replacement
필요한 것
    1. Vivitar DVR 781HD Screen Replacement, Front Case: 1 단계, 이미지 3개 중 1개 Vivitar DVR 781HD Screen Replacement, Front Case: 1 단계, 이미지 3개 중 2개 Vivitar DVR 781HD Screen Replacement, Front Case: 1 단계, 이미지 3개 중 3개
      • Begin with the camcorder lens up on a clear working surface.
      • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
      댓글 쓰기
    2. Vivitar DVR 781HD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
      댓글 쓰기
    3. Vivitar DVR 781HD Screen Replacement: 3 단계, 이미지 3개 중 1개 Vivitar DVR 781HD Screen Replacement: 3 단계, 이미지 3개 중 2개 Vivitar DVR 781HD Screen Replacement: 3 단계, 이미지 3개 중 3개
      • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
      • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
      댓글 쓰기
    1. Vivitar DVR 781HD Screen Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Vivitar DVR 781HD Screen Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
      • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
      댓글 쓰기
    2. Vivitar DVR 781HD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Gently lift the motherboard, handling it by the edges.
      댓글 쓰기
    1. Vivitar DVR 781HD Screen Replacement, Screen: 6 단계, 이미지 2개 중 1개 Vivitar DVR 781HD Screen Replacement, Screen: 6 단계, 이미지 2개 중 2개
      • Remove the two 4mm Phillips #1 screws holding the screen assembly to the motherboard.
      댓글 쓰기
    2. Vivitar DVR 781HD Screen Replacement: 7 단계, 이미지 2개 중 1개 Vivitar DVR 781HD Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Turn the motherboard and screen over.
      • Gently lift the screen from the motherboard, handling it by the edges of the black plastic holder.
      댓글 쓰기
    3. Vivitar DVR 781HD Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Using a soldering iron, melt the solder connection between the screen's ribbon cable and the motherboard. Pull the ribbon cable away before the solder solidifies.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nathan McDaniel
회원 가입일: 02/13/16
592 평판
안내서 3개를 작성함
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016 회원
IUPUI-WILSON-S16S54G6
3 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 975
