주요 콘텐츠로 건너뛰기
Voluas VL001 USB Replacement
필요한 것
  1. Voluas VL001 USB Replacement, Storage Tank: 1 단계, 이미지 3개 중 1개 Voluas VL001 USB Replacement, Storage Tank: 1 단계, 이미지 3개 중 2개 Voluas VL001 USB Replacement, Storage Tank: 1 단계, 이미지 3개 중 3개
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 USB Replacement, Battery: 2 단계, 이미지 3개 중 1개 Voluas VL001 USB Replacement, Battery: 2 단계, 이미지 3개 중 2개 Voluas VL001 USB Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 USB Replacement, Housing: 3 단계, 이미지 3개 중 1개 Voluas VL001 USB Replacement, Housing: 3 단계, 이미지 3개 중 2개 Voluas VL001 USB Replacement, Housing: 3 단계, 이미지 3개 중 3개
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 USB Replacement: 4 단계, 이미지 2개 중 1개 Voluas VL001 USB Replacement: 4 단계, 이미지 2개 중 2개
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 USB Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 USB Replacement, USB: 6 단계, 이미지 2개 중 1개 Voluas VL001 USB Replacement, USB: 6 단계, 이미지 2개 중 2개
    • Using a Phillips #2 screwdriver, carefully remove the two 11.2 mm screws on either side of the USB port.
  7. Voluas VL001 USB Replacement: 7 단계, 이미지 2개 중 1개 Voluas VL001 USB Replacement: 7 단계, 이미지 2개 중 2개
    • Using your wire strippers/pliers, cut the three wires that are connected to the USB port.
  8. Voluas VL001 USB Replacement: 8 단계, 이미지 3개 중 1개 Voluas VL001 USB Replacement: 8 단계, 이미지 3개 중 2개 Voluas VL001 USB Replacement: 8 단계, 이미지 3개 중 3개
    • Using your wire strippers/pliers, gently crimp the plastic insulation on the wire. Do this several times around the wire to make sure that you can pull it off.
    • Because the wire is so thin, it can be easy to accidentally cut all the way through the wire on this step. Take care to only cut through the insulation.
    • You will want to see a score line in the insulation all around the wire like this.
    • Pull the end of the insulation off, exposing the wire.
  9. Voluas VL001 USB Replacement: 9 단계, 이미지 2개 중 1개 Voluas VL001 USB Replacement: 9 단계, 이미지 2개 중 2개
    • Put the exposed wire on the solder patch, making sure it has good contact with the metal.
    • Solder the wire on to the solder patch.
    • Repeat steps 8 and 9 for the other two wires.
결론
작성자
2다른 기여자 명과 함께
Merari Aniga
회원 가입일: 01/30/24
459 평판
안내서 4개를 작성함
Utah Tech University, Team 1-3, McMurrin Spring 2024 Utah Tech University, Team 1-3, McMurrin Spring 2024 회원
UTAHTECH-MCMURRIN-S24S1G3
2 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 258
