주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vtech InnoTab 3S Camera Replacement
필요한 것
    1. Vtech InnoTab 3S Camera Replacement, Rear Panel: 1 단계, 이미지 3개 중 1개 Vtech InnoTab 3S Camera Replacement, Rear Panel: 1 단계, 이미지 3개 중 2개 Vtech InnoTab 3S Camera Replacement, Rear Panel: 1 단계, 이미지 3개 중 3개
      • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
      • Remove the batteries from the device.
      댓글 쓰기
    2. Vtech InnoTab 3S Camera Replacement: 2 단계, 이미지 2개 중 1개 Vtech InnoTab 3S Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
      댓글 쓰기
    3. Vtech InnoTab 3S Camera Replacement: 3 단계, 이미지 3개 중 1개 Vtech InnoTab 3S Camera Replacement: 3 단계, 이미지 3개 중 2개 Vtech InnoTab 3S Camera Replacement: 3 단계, 이미지 3개 중 3개
      • Using a nylon spudger, remove the five caps that hide the screws.
      • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
      • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
      • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
      댓글 쓰기
    4. Vtech InnoTab 3S Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully remove the rear panel from the front panel of the device.
      • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
      댓글 쓰기
    1. Vtech InnoTab 3S Camera Replacement, Camera: 5 단계, 이미지 2개 중 1개 Vtech InnoTab 3S Camera Replacement, Camera: 5 단계, 이미지 2개 중 2개
      • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
      • The connection between the motherboard and the camera is located at the near the top of the device.
      • Remove the camera and the connecting wire from the the clip and attach the replacement cameras connection to the latch on the motherboard.
      • Carefully lower the latch until you hear a click to secure the new camera to the device.
      • Pulling or tugging on the connection between the camera and the circuit board may cause damage to the connection.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Karina Garcia
회원 가입일: 08/30/15
878 평판
안내서 6개를 작성함
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G2
4 회원들
안내서 45개를 작성함
4가이드 댓글
Where do you get the replacement camera? I can't find them online.
rongennero - 답글 공유
I just did this whole thing...hoping it was a reset to the camera or something, but no, you need a replacement camera. Might be helpful to add that to the PARTS NEEDED part at the top, instead of saying "no parts required." UUGHHHH!
jpimash - 답글 공유
Where can i buy the camera?
Stephan Meyer - 답글 공유
kind of useless to post a replacement guide without suggesting a source for that replacement!!
Glen Fletcher - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 2,381
