주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vtech Innotab 3 Button Replacement
필요한 것
    1. Vtech Innotab 3 Button Replacement, Rear Panel: 1 단계, 이미지 3개 중 1개 Vtech Innotab 3 Button Replacement, Rear Panel: 1 단계, 이미지 3개 중 2개 Vtech Innotab 3 Button Replacement, Rear Panel: 1 단계, 이미지 3개 중 3개
      • Slide the battery compartment door lock down.
      • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
      • Carefully remove the batteries from the battery compartment.
      • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
      댓글 쓰기
    2. Vtech Innotab 3 Button Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
      댓글 쓰기
    3. Vtech Innotab 3 Button Replacement: 3 단계, 이미지 3개 중 1개 Vtech Innotab 3 Button Replacement: 3 단계, 이미지 3개 중 2개 Vtech Innotab 3 Button Replacement: 3 단계, 이미지 3개 중 3개
      • There are three hidden screws on the back of the device, two at the top and one near the bottom.
      • Using a nylon or metal spudger, remove the three caps that hide the screws.
      • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
      댓글 쓰기
    4. Vtech Innotab 3 Button Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
      댓글 쓰기
    1. Vtech Innotab 3 Button Replacement, Button Repair: 5 단계, 이미지 3개 중 1개 Vtech Innotab 3 Button Replacement, Button Repair: 5 단계, 이미지 3개 중 2개 Vtech Innotab 3 Button Replacement, Button Repair: 5 단계, 이미지 3개 중 3개
      • Remove the four 7.6 mm screws using a PH00 screwdriver.
      • Lift the circuit board up to give yourself room to remove the buttons.
      댓글 쓰기
    2. Vtech Innotab 3 Button Replacement: 6 단계, 이미지 3개 중 1개 Vtech Innotab 3 Button Replacement: 6 단계, 이미지 3개 중 2개 Vtech Innotab 3 Button Replacement: 6 단계, 이미지 3개 중 3개
      • Using a nylon or metal spudger, lift up the buttons to remove them from their holding. they should just pop out of place.
      • The buttons are joined together in pairs, be sure not to break them apart during removal.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Zach Diviney
회원 가입일: 03/11/15
419 평판
안내서 4개를 작성함
Colorado Springs, Team 5-4, Panko Spring 2015 Colorado Springs, Team 5-4, Panko Spring 2015 회원
UCCS-PANKO-S15S5G4
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 994
