주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wacom Cintiq 24HD Display Control Buttons Replacement
필요한 것
    1. Wacom Cintiq 24HD Display Control Buttons Replacement, Stand: 1 단계, 이미지 1개 중 1개
      • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
      • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
      댓글 쓰기
    2. Wacom Cintiq 24HD Display Control Buttons Replacement: 2 단계, 이미지 3개 중 1개 Wacom Cintiq 24HD Display Control Buttons Replacement: 2 단계, 이미지 3개 중 2개 Wacom Cintiq 24HD Display Control Buttons Replacement: 2 단계, 이미지 3개 중 3개
      • Place the device screen down on a flat surface.
      • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
      댓글 쓰기
    3. Wacom Cintiq 24HD Display Control Buttons Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
      댓글 쓰기
    1. Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: 4 단계, 이미지 3개 중 1개 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: 4 단계, 이미지 3개 중 2개 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: 4 단계, 이미지 3개 중 3개
      • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
      • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
      • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
      • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
      댓글 쓰기
    2. Wacom Cintiq 24HD Display Control Buttons Replacement: 5 단계, 이미지 2개 중 1개 Wacom Cintiq 24HD Display Control Buttons Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
      • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
      • The latches on the back panel will make loud clicking noises when opening.
      • Remove the panel by lifting it up and off of the device.
      댓글 쓰기
    1. Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: 6 단계, 이미지 3개 중 1개 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: 6 단계, 이미지 3개 중 2개 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: 6 단계, 이미지 3개 중 3개
      • Remove the two 8mm screws from the metal button plate using a Phillips #2 screwdriver and by turning clockwise.
      • Remove metal holding plate by lifting up and off of the button board.
      댓글 쓰기
    2. Wacom Cintiq 24HD Display Control Buttons Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the button board by pinching the wiring close to the connector and gently pulling straight out from the port.
      댓글 쓰기
    3. Wacom Cintiq 24HD Display Control Buttons Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the button cover by pushing the buttons out of their holes and pulling the cover up.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jay Sung
회원 가입일: 10/08/18
499 평판
안내서 4개를 작성함
Cal Poly, Team S15-G3, White Fall 2018 Cal Poly, Team S15-G3, White Fall 2018 회원
CPSU-WHITE-F18S15G3
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 35
전체 시간: 2,019
