주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wacom Intuos4 Express Keys Replacement
필요한 것
    1. Wacom Intuos4 Express Keys Replacement, Casing: 1 단계, 이미지 3개 중 1개 Wacom Intuos4 Express Keys Replacement, Casing: 1 단계, 이미지 3개 중 2개 Wacom Intuos4 Express Keys Replacement, Casing: 1 단계, 이미지 3개 중 3개
      • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
      • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
      댓글 쓰기
    2. Wacom Intuos4 Express Keys Replacement: 2 단계, 이미지 2개 중 1개 Wacom Intuos4 Express Keys Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
      • Separate the outer casing from the rest of the tablet.
      댓글 쓰기
    1. Wacom Intuos4 Express Keys Replacement, Express Keys: 3 단계, 이미지 3개 중 1개 Wacom Intuos4 Express Keys Replacement, Express Keys: 3 단계, 이미지 3개 중 2개 Wacom Intuos4 Express Keys Replacement, Express Keys: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Lift yellow tape covering the flat wires with a pair of tweezers.
      • Lift the black plastic clip holding the flat wire to the connector.
      • This should be done with a plastic tool to avoid damaging the contacts.
      • Pull on the white plastic tab to disconnect the flat wire.
      • Do this for the left and right express key chips.
      댓글 쓰기
    2. Wacom Intuos4 Express Keys Replacement: 4 단계, 이미지 1개 중 1개
      • Pull the black plastic clip away from the flat wire connector, and pull the flat wire out.
      • It may be easier to pull with a tool on one side, and with your hand on the other at the same time.
      댓글 쓰기
    3. Wacom Intuos4 Express Keys Replacement: 5 단계, 이미지 1개 중 1개
      • Use a #1 Phillips head screwdriver to unscrew the four 5mm screws on the express key board you want to replace.
      댓글 쓰기
    4. Wacom Intuos4 Express Keys Replacement: 6 단계, 이미지 2개 중 1개 Wacom Intuos4 Express Keys Replacement: 6 단계, 이미지 2개 중 2개
      • Lift the board and rubber buttons up from the case.
      • Separate the rubber buttons from the board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Aidan Sullivan
회원 가입일: 10/26/22
293 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-6, Botvin Fall 2022 UMass Dartmouth, Team 3-6, Botvin Fall 2022 회원
UMASSD-BOTVIN-F22S3G6
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 37
전체 시간: 675
