주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wen 2307 Speed Adjustment Assembly Replacement
필요한 것
  1. Wen 2307 Speed Adjustment Assembly Replacement, Front Panel: 1 단계, 이미지 1개 중 1개
    • Unscrew the locking sleeve.
    댓글 쓰기
  2. Wen 2307 Speed Adjustment Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the hanging clip.
    댓글 쓰기
  3. Wen 2307 Speed Adjustment Assembly Replacement: 3 단계, 이미지 2개 중 1개 Wen 2307 Speed Adjustment Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the six 8mm PH2 screws.
    댓글 쓰기
  4. Wen 2307 Speed Adjustment Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
    댓글 쓰기
  5. Wen 2307 Speed Adjustment Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
    댓글 쓰기
  6. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: 6 단계, 이미지 2개 중 1개 Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: 6 단계, 이미지 2개 중 2개
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
    댓글 쓰기
  7. Wen 2307 Speed Adjustment Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the place boar carefully.
    댓글 쓰기
  8. Wen 2307 Speed Adjustment Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Pull out the power cable connectors.
    댓글 쓰기
  9. Wen 2307 Speed Adjustment Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Pull out the cord sleve for the new cable replacement.
    댓글 쓰기
  10. Wen 2307 Speed Adjustment Assembly Replacement, Speed Adjustment Assembly: 10 단계, 이미지 1개 중 1개
    • Remove the connected wiring from the circuit board.
    댓글 쓰기
  11. Wen 2307 Speed Adjustment Assembly Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the single 4mm screw retaining the circuit board.
    댓글 쓰기
  12. Wen 2307 Speed Adjustment Assembly Replacement: 12 단계, 이미지 1개 중 1개
    • Gently pry the circuit board from the back piece.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Dominick Chavez
회원 가입일: 02/08/16
137 평판
안내서 1개를 작성함
USF Tampa, Team 12-1, Eyestone Spring 2016 USF Tampa, Team 12-1, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S12G1
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 1,171
