주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Whirlpool Refrigerator Condenser Fan Replacement
필요한 것
  1. Whirlpool Refrigerator Condenser Fan Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
    댓글 쓰기
  2. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
    댓글 쓰기
  3. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 3개
    • Pull the rear panel off the chassis to remove it.
    댓글 쓰기
  4. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: 4 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: 4 단계, 이미지 2개 중 2개
    • Disconnect the connector attached to the condenser fan.
    댓글 쓰기
  5. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: 5 단계, 이미지 3개 중 3개
    • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
    댓글 쓰기
  6. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the condenser fan motor: 6 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the condenser fan motor to the chassis.
    댓글 쓰기
  7. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: 7 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: 7 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: 7 단계, 이미지 3개 중 3개
    • Rotate the motor housing through its slot in the chassis.
    • Remove the motor.
    댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,990 평판
안내서 89개를 작성함
1가이드 댓글
Saludos una consulta el giro del motor es antihorario???
Edward Vasquez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 32
지난 30일: 173
전체 시간: 5,374
