주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Whirlpool Refrigerator Icemaker Assembly Replacement
필요한 것
    1. Whirlpool Refrigerator Icemaker Assembly Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      댓글 쓰기
    1. Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
      • Depending on your repair, open one or both doors.
      댓글 쓰기
    1. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 2개
      • Pull the icemaker tray completely out of its slot in the chassis.
      댓글 쓰기
    2. Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 2개
      • Remove the screw(s) securing the icemaker assembly.
      • The second photo shows the potential screw locations in a removed icemaker assembly.
      댓글 쓰기
    3. Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 3개
      • Pull the icemaker assembly off its slot in the chassis.
      • Let the assembly hang to access its connectors.
      댓글 쓰기
    4. Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 3개
      • Disconnect any connectors attached to the icemaker assembly.
      댓글 쓰기
    5. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 7 단계, 이미지 1개 중 1개
      • Remove the icemaker assembly.
      댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,990 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 67
지난 30일: 377
전체 시간: 9,940
