주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Whirlpool Refrigerator Start Relay Assembly Replacement
필요한 것
    1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      댓글 쓰기
    1. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 3개
      • Remove the screw(s) securing the rear panel.
      • Loosen the screw securing the water hose enough for the rear panel to freely move.
      댓글 쓰기
    2. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 3개
      • Pull the rear panel off the chassis to remove it.
      댓글 쓰기
    1. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: 4 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: 4 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: 4 단계, 이미지 3개 중 3개
      • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
      댓글 쓰기
    2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: 5 단계, 이미지 3개 중 3개
      • Pull the metal clip out its hole in the top of the start relay assembly.
      • Rest the clip next to the assembly.
      댓글 쓰기
    3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: 6 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: 6 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: 6 단계, 이미지 3개 중 3개
      • Pull the start relay assembly straight off its prongs in the chassis.
      • Remove the start relay assembly.
      • The assembly consists of the run capacitor, start relay, and overload relay.
      댓글 쓰기
    4. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: 7 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: 7 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: 7 단계, 이미지 3개 중 3개
      • If you own a multimeter, you can test the start relay and overload relay's resistance.
      • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
      댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,990 평판
안내서 89개를 작성함
3가이드 댓글
Is it universal part
dyannatorres@yahoo.com - 답글 공유
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO - 답글 공유
Last part is not clear about where to put multimeter probes for testing each component. It makes the whole exercise useless.
Shafeeq Qaiser - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 125
지난 30일: 451
전체 시간: 16,944
