주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Whirlpool Refrigerator Temperature Control Board Replacement
필요한 것
    1. Whirlpool Refrigerator Temperature Control Board Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      댓글 쓰기
    1. Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
      • Depending on your repair, open one or both doors.
      댓글 쓰기
    1. Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: 3 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: 3 단계, 이미지 2개 중 2개
      • Remove the screw(s) securing the temperature control board assembly.
      • The second photo shows the potential screw locations in a removed assembly.
      댓글 쓰기
    2. Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: 4 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: 4 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: 4 단계, 이미지 3개 중 3개
      • Pull the temperature control board assembly off its slot in the chassis.
      • Let the assembly hang to access its connectors.
      댓글 쓰기
    3. Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: 5 단계, 이미지 3개 중 3개
      • Disconnect any connectors attached to the temperature control board assembly.
      댓글 쓰기
    4. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the assembly: 6 단계, 이미지 1개 중 1개
      • Remove the temperature control board assembly.
      댓글 쓰기
    5. Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: 7 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: 7 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: 7 단계, 이미지 3개 중 3개
      • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
      • Use another flathead screwdriver to pry up the board from its housing.
      댓글 쓰기
    6. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the temperature control board: 8 단계, 이미지 1개 중 1개
      • Pull the temperature control board straight out of its housing to remove it.
      댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,990 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 142
전체 시간: 2,616
