소개
Follow this guide to swap a broken lid lock so your washer will start cycles and unlock correctly. A failed lock can leave the basket disabled or the lid stuck shut, and the newest Whirlpool design removes differently from earlier models. Replacing it yourself restores normal operation without a service call.
필요한 것
2 단계 Remove the rear top screws and wire cover
Remove the two quarter-inch screws at the back corners that secure the top panel.
Remove the quarter-inch screw in the small wire-harness cover and lift the cover off.
3 단계 Remove the console back cover
Remove the five screws holding the rear console cover and pull the metal cover away.
4 단계 Release the console
Push the basket rearward, reach under the lid, and press the two hidden spring clips to pop the console loose, or slide a flexible plastic card into the gap from the front to release them.
Swing the console up, press the tab on its single wire connector, and unplug it from the control board.
5 단계 Disconnect the top-panel wiring
Unplug the lid-lock harness and any other wiring leading into the top panel.
Pull the small pressure hose straight off its port on the control board.
Remove the green ground strap held by a quarter-inch screw if it blocks the panel.
6 단계 Raise and support the top
Raise the rear edge of the lid and top assembly high, push it forward to free the rear clips, then move to the front and lift upward while pulling back to release the front tabs.
7 단계 Remove the lid-lock bezel
Slip a fingernail or thin plastic tool under the bezel tabs on the lid surface and gently pry it free from the lock body.
8 단계 Release the lid lock assembly
Push the lock assembly to the left, lift it slightly, then slide it right and out of the lid opening.
9 단계 Free the lid-lock harness
Use a flat-blade screwdriver to pry the two metal retainers open and pull the harness trunk out of them.
Press the tab on the small plastic retainer and release the harness from the top side of the lid.
10 단계 Route the new lid-lock harness
Thread the replacement harness through the lid hole and seat it into the two metal clips.
Snap the plastic retainer back into the lid to secure the harness slack.
11 단계 Install the new lid lock
Insert the top of the lock body into the left side of the opening, press it flush against the lid, and slide it firmly to the right until the side tab clicks.
12 단계 Reinstall the bezel
Align the bezel over the lock and press until all four tabs click flat against the lid surface.
13 단계 Lower the top
Guide the top back onto the chassis, rock it forward, down, and back until the front and rear clips snap flush.
Lift the rear edge again slightly if needed to be sure every latch is locked tight.
14 단계 Reconnect the console
Reinstall the green ground strap with its screw and plug every harness back into the control board.
Set the console on its hinges and push until the spring clips click into the lid housing.
15 단계 Reinstall the rear covers
Install the metal console back cover with its five screws.
Replace the wire-harness cover screw, then reinstall the two quarter-inch top screws removed earlier.
16 단계 Restore power and water
Open the water supply valves and plug the washer back into the outlet.
17 단계 Run the calibration cycle
Verify all lights are off, then press the same three keys in order three times within eight seconds (1-2-3, 1-2-3, 1-2-3) to enter diagnostics.
Wait for the indicator lamps to flash, press the second key (Rinse) once, then press Start to launch the automatic test cycle for calibration.
Repair didn't go as planned? Ask our Answers community for help.
