주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wire Bonder Thread Spool Replacement
동영상 개요
  1. Wire Bonder Thread Spool Replacement, Wire Bonder Thread Spool Replacement: 1 단계, 이미지 1개 중 1개
    • Remove the seal from the wire spool. Take care not to cut the thread at the red marking!
    댓글 쓰기
  2. Wire Bonder Thread Spool Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the spool in the assembly.
    • Make sure that the spool runs clockwise.
    댓글 쓰기
    • Pull the thread downward.
    댓글 쓰기
  3. Wire Bonder Thread Spool Replacement, Placing the thread into the infeeder: 4 단계, 이미지 1개 중 1개
    • Place the thread between the guides of the infeeder.
    • Pull the engaging knob which is situated to the left of the infeeder rolls, to the left.
    • Now there is a gap between the infeeder rolls into which the wire can be inserted safely.
    댓글 쓰기
  4. Wire Bonder Thread Spool Replacement, Placing the thread behind the sensors: 5 단계, 이미지 1개 중 1개
    • Cut the wire.
    • Place the wire behind the sensors (the black box in the foreground).
    댓글 쓰기
  5. Wire Bonder Thread Spool Replacement, Placing the thrad in the outfeeder: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the tweezers to place the wire between the two metal guides of the outfeeder.
    댓글 쓰기
  6. Wire Bonder Thread Spool Replacement, Put the wire into the tube: 7 단계, 이미지 1개 중 1개
    • Use the tweezers to lead the wire into the tube from below.
    댓글 쓰기
  7. Wire Bonder Thread Spool Replacement, Automatic feeding: 8 단계, 이미지 1개 중 1개
    • Push the spring of the outfeeder and the "Feed and Capture" button simultaneously for automatic feeding.
    • Make sure that the rolls of the outfeeder are close together so that the wire is gripped firmly.
    • Before starting automatic feeding, turn off "Run or Service" and activate "Feed or Capture".
    댓글 쓰기
  8. Wire Bonder Thread Spool Replacement, Manual Feeding: 9 단계, 이미지 2개 중 1개 Wire Bonder Thread Spool Replacement, Manual Feeding: 9 단계, 이미지 2개 중 2개
    • It is also possible to feed the wire manually into the outfeeder tube.
    • In order to do so, press the "Run and Service" button and turn the left-hand wheel clockwise. The wire is now fed ino the tube.
    댓글 쓰기
  9. Wire Bonder Thread Spool Replacement: 10 단계, 이미지 1개 중 1개
    • Check visually if the wire is fed into the bonding head.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Beate Richter
회원 가입일: 03/20/19
181 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 27
전체 시간: 350
