주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wireless Card Replacement
필요한 것
  1. Wireless Card  Replacement, HP 17-x061nr  Disassembly: 1 단계, 이미지 3개 중 1개 Wireless Card  Replacement, HP 17-x061nr  Disassembly: 1 단계, 이미지 3개 중 2개 Wireless Card  Replacement, HP 17-x061nr  Disassembly: 1 단계, 이미지 3개 중 3개
    • With the laptop upside down, remove the battery by hand and the twelve 7.0 mm screws that are holding the back case to the front. Use a JIS #0 screwdriver to remove the screws.
    댓글 쓰기
  2. Wireless Card  Replacement: 2 단계, 이미지 2개 중 1개 Wireless Card  Replacement: 2 단계, 이미지 2개 중 2개
    • Peel back the rubber footrests located next to the battery, on the left and right sides.
    • Remove the two 7.0 mm screws underneath the rubber feet using a JIS #0 screwdriver.
    댓글 쓰기
  3. Wireless Card  Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the optical drive out and away from the laptop.
    댓글 쓰기
  4. Wireless Card  Replacement: 4 단계, 이미지 3개 중 1개 Wireless Card  Replacement: 4 단계, 이미지 3개 중 2개 Wireless Card  Replacement: 4 단계, 이미지 3개 중 3개
    • Flip the computer over and use a plastic opening tool to wedge between the back and front cases.
    • Trace the perimeter of the laptop. Make sure to keep the tool inserted between the front and back cases. You will hear popping sounds as the back case becomes disengaged from the front plate.
    • Flip the laptop over and lift the back case off. Now you have access to all of the internal hardware.
    댓글 쓰기
  5. Wireless Card  Replacement, Wireless Card: 5 단계, 이미지 2개 중 1개 Wireless Card  Replacement, Wireless Card: 5 단계, 이미지 2개 중 2개
    • Locate the wireless card in the center of the computer and attached to the motherboard.
    • Locate the 4.0 mm hidden screw holding the wireless card and gently remove it.
    댓글 쓰기
  6. Wireless Card  Replacement: 6 단계, 이미지 2개 중 1개 Wireless Card  Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the old wireless card and replace with the new wireless card. Gently screw it into place.
    • Be sure to keep the replacement within the package until you are ready to place it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Curtis Haley
회원 가입일: 02/23/18
520 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 100
전체 시간: 10,796
