주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wireless card replacement
필요한 것
추천 문서
  1. Wireless card replacement, Remove the battery: 1 단계, 이미지 3개 중 1개 Wireless card replacement, Remove the battery: 1 단계, 이미지 3개 중 2개 Wireless card replacement, Remove the battery: 1 단계, 이미지 3개 중 3개
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
    댓글 쓰기
  2. Wireless card replacement, Remove the captive screw of the service door: 2 단계, 이미지 1개 중 1개
    • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
    댓글 쓰기
  3. Wireless card replacement, Remove the service door: 3 단계, 이미지 3개 중 1개 Wireless card replacement, Remove the service door: 3 단계, 이미지 3개 중 2개 Wireless card replacement, Remove the service door: 3 단계, 이미지 3개 중 3개
    • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
    • Continue along the short edges.
    • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
    댓글 쓰기
  4. Wireless card replacement, Identify the components: 4 단계, 이미지 1개 중 1개
    • RAM memory modules
    • HDD (Hard Disk Drive)
    • mSATA SSD slot
    • Wifi & BT module (Wireless card)
    댓글 쓰기
  5. Wireless card replacement, Disconnect the antenna cables & unfasten the screw: 5 단계, 이미지 3개 중 1개 Wireless card replacement, Disconnect the antenna cables & unfasten the screw: 5 단계, 이미지 3개 중 2개 Wireless card replacement, Disconnect the antenna cables & unfasten the screw: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    댓글 쓰기
  6. Wireless card replacement, Substitute the wireless card: 6 단계, 이미지 3개 중 1개 Wireless card replacement, Substitute the wireless card: 6 단계, 이미지 3개 중 2개 Wireless card replacement, Substitute the wireless card: 6 단계, 이미지 3개 중 3개
    • Grab the standard wireless card as it is shown in the first picture and gently pull it away at the tilt angle.
    • Place the M2.0×2.5 screw in the hole of the new wifi module, tilt it, and gently insert it in its slot. Then press the wireless card down with a hand and fasten the screw using a PH #00 with the other one.
    • Using the tweezers center and hold the connectors of the antenna cables over their terminals and then press them straight down gently using your finger. Cable 1 goes with the Main terminal and Cable 2 with the Aux terminal.
    댓글 쓰기
결론
Well, that’s it! Take a short break if you like and then start to reassemble your laptop from the step #3 in reverse order. Once you turn the laptop on, install the new drivers and it's done ;) Cheers
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Roberto Bartolacci
회원 가입일: 02/10/18
1,548 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 12
지난 30일: 74
전체 시간: 2,794
