주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Withings Smart Body Analyzer LCD Screen Replacement
필요한 것
    1. Withings Smart Body Analyzer LCD Screen Replacement, Withings Smart Body Analyzer Disassembly: 1 단계, 이미지 1개 중 1개
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      댓글 쓰기
    2. Withings Smart Body Analyzer LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Withings Smart Body Analyzer LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Withings Smart Body Analyzer LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      댓글 쓰기
    3. Withings Smart Body Analyzer LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Withings Smart Body Analyzer LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      댓글 쓰기
    1. Withings Smart Body Analyzer LCD Screen Replacement, LCD Screen: 4 단계, 이미지 2개 중 1개 Withings Smart Body Analyzer LCD Screen Replacement, LCD Screen: 4 단계, 이미지 2개 중 2개
      • After the tempered glass panel has been removed, the screen can be accessed and is connected by a ribbon cable via the circuit board.
      • Gently remove the wire from the circuit board by gently pushing downward and away from the screen, on the metal tab that connects the wire to the circuit board.
      댓글 쓰기
    2. Withings Smart Body Analyzer LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Using the Phillips screwdriver head, unscrew the two screws that hold the screen in place.
      댓글 쓰기
    3. Withings Smart Body Analyzer LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • The screen should be free from all constraints and all that is left is to carefully lift and remove the screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
omar shehadi
회원 가입일: 03/22/17
219 평판
안내서 2개를 작성함
UMass Dartmouth, Team S4-G1, Julie Spring 2017 UMass Dartmouth, Team S4-G1, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G1
4 회원들
안내서 5개를 작성함
2가이드 댓글
Where can I get a new LCD screen for replacement?
Putra Jaya - 답글 공유
problem is that I didn´t find new LCD on the internet :-(
krwell - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 49
전체 시간: 4,191
