주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Withings Smart Body Analyzer Motherboard Replacement
필요한 것
    1. Withings Smart Body Analyzer Motherboard Replacement, Withings Smart Body Analyzer Disassembly: 1 단계, 이미지 1개 중 1개
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      댓글 쓰기
    2. Withings Smart Body Analyzer Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Withings Smart Body Analyzer Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Withings Smart Body Analyzer Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      댓글 쓰기
    3. Withings Smart Body Analyzer Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Withings Smart Body Analyzer Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      댓글 쓰기
    1. Withings Smart Body Analyzer Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Withings Smart Body Analyzer Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
      • Using the Phillips-head screwdriver, unscrew the two screws that are securing the motherboard in place
      댓글 쓰기
    2. Withings Smart Body Analyzer Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Using a plastic spudger, disconnect the LCD display's ribbon cable from the motherboard.
      댓글 쓰기
    3. Withings Smart Body Analyzer Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Once the two screws and the ribbon cable are detached, remove the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ashley Dauphinee
회원 가입일: 03/22/17
323 평판
안내서 2개를 작성함
UMass Dartmouth, Team S4-G1, Julie Spring 2017 UMass Dartmouth, Team S4-G1, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G1
4 회원들
안내서 5개를 작성함
2가이드 댓글
My Wifi Body scale cannot connect to Wifi or my app. Everything else works. Where can I have it repaired. Please advise.
Mel - 답글 공유
where do you get the motherboard?
cost?
donald taylor - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 29
지난 30일: 130
전체 시간: 8,093
