주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Withings Smart Body Analyzer Pressure Sensor Replacement
필요한 것
    1. Withings Smart Body Analyzer Pressure Sensor Replacement, Withings Smart Body Analyzer Disassembly: 1 단계, 이미지 1개 중 1개
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      댓글 쓰기
    2. Withings Smart Body Analyzer Pressure Sensor Replacement: 2 단계, 이미지 3개 중 1개 Withings Smart Body Analyzer Pressure Sensor Replacement: 2 단계, 이미지 3개 중 2개 Withings Smart Body Analyzer Pressure Sensor Replacement: 2 단계, 이미지 3개 중 3개
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      댓글 쓰기
    3. Withings Smart Body Analyzer Pressure Sensor Replacement: 3 단계, 이미지 2개 중 1개 Withings Smart Body Analyzer Pressure Sensor Replacement: 3 단계, 이미지 2개 중 2개
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      댓글 쓰기
    1. Withings Smart Body Analyzer Pressure Sensor Replacement, Pressure Sensor: 4 단계, 이미지 1개 중 1개
      • Notice the red and black wires connecting the circuit board to each of the pressure sensors.
      • Using a soldering iron and de-soldering braid, remove the soldered red and black wires from the circuit board
      댓글 쓰기
    2. Withings Smart Body Analyzer Pressure Sensor Replacement: 5 단계, 이미지 2개 중 1개 Withings Smart Body Analyzer Pressure Sensor Replacement: 5 단계, 이미지 2개 중 2개
      • Use a Phillips-head screwdriver to remove the screw from the sensor. There will be two screws per sensor.
      댓글 쓰기
    3. Withings Smart Body Analyzer Pressure Sensor Replacement: 6 단계, 이미지 2개 중 1개 Withings Smart Body Analyzer Pressure Sensor Replacement: 6 단계, 이미지 2개 중 2개
      • Remove any sensors you need and you are now ready to replace or repair depending on your needs.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ashley Dauphinee
회원 가입일: 03/22/17
323 평판
안내서 2개를 작성함
UMass Dartmouth, Team S4-G1, Julie Spring 2017 UMass Dartmouth, Team S4-G1, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G1
4 회원들
안내서 5개를 작성함
3가이드 댓글
Where do I get those replacements?
karina - 답글 공유
where can I buy pressure sensors?
Andrey Kolesov - 답글 공유
The issue is not the pressure sensor, but a weak area within the foot.
Having taken my scales apart to repair them I found the the foot (pictured within the plastic ring above) has a metal disc in it, that is supported by a few weak plastic ribs that easily damage. I filled them in with Araldyte to create a firm level surface and all is good again.
As a design engineer who fault-finds all day, I would say this is either poor design (an oversight), or brilliant salesmanship (a weak point that allows Withings to sell more scales). Which is true? Only they know.
FlashingIcon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 50
전체 시간: 4,786
