주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wolf Gourmet WGTR102S Electrical Connection Replacement
필요한 것
    1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Outer Shell: 1 단계, 이미지 1개 중 1개
      • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
      댓글 쓰기
    2. Wolf Gourmet WGTR102S Electrical Connection Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
      댓글 쓰기
    3. Wolf Gourmet WGTR102S Electrical Connection Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the crumb collector located on the bottom of the toaster.
      댓글 쓰기
    4. Wolf Gourmet WGTR102S Electrical Connection Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
      댓글 쓰기
    5. Wolf Gourmet WGTR102S Electrical Connection Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
      • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
      댓글 쓰기
    6. Wolf Gourmet WGTR102S Electrical Connection Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the final 8mm screw in the slide lever.
      • The lever can now pull away from the entire unit.
      댓글 쓰기
    7. Wolf Gourmet WGTR102S Electrical Connection Replacement: 7 단계, 이미지 1개 중 1개
      • Remove toaster's outer shell by lifting straight up.
      • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
      댓글 쓰기
    8. Wolf Gourmet WGTR102S Electrical Connection Replacement: 8 단계, 이미지 2개 중 1개 Wolf Gourmet WGTR102S Electrical Connection Replacement: 8 단계, 이미지 2개 중 2개
      • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
      • Remove the outer shell from the device.
      댓글 쓰기
    1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Electrical Connection: 9 단계, 이미지 1개 중 1개
      • Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
      댓글 쓰기
    2. Wolf Gourmet WGTR102S Electrical Connection Replacement: 10 단계, 이미지 1개 중 1개
      • Use pliers to pull apart the three electrical connectors pictured in the graphic.
      댓글 쓰기
    3. Wolf Gourmet WGTR102S Electrical Connection Replacement: 11 단계, 이미지 1개 중 1개
      • Replace the electrical connectors.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ryan Funchess
회원 가입일: 04/19/18
715 평판
안내서 5개를 작성함
Cal Poly, Team S22-G5, Maness Spring 2018 Cal Poly, Team S22-G5, Maness Spring 2018 회원
CPSU-MANESS-S18S22G5
4 회원들
안내서 10개를 작성함
1가이드 댓글
Ryan Funchess
Thank you for you work on this toaster. My customer is happy.
Adam Hunsinger - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 39
전체 시간: 1,399
