주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wooting 60HE Keycap Replacement
필요한 것
  1. Wooting 60HE Keycap Replacement, Keycap: 1 단계, 이미지 1개 중 1개
    • Use a small, soft bristle brush to remove small hairs or dust from the keyboard.
    • For this replacement, we will be replacing the "A" keycap.
    댓글 쓰기
  2. Wooting 60HE Keycap Replacement: 2 단계, 이미지 2개 중 1개 Wooting 60HE Keycap Replacement: 2 단계, 이미지 2개 중 2개
    • Hook the two metal brackets of the keycap puller at a slight angle on the corners of the key.
    • Slightly tug upwards, and the key should come out smoothly. Place the key to the side.
    • It is essential to be gentle; excessive force can cause cracks or scratches on the key.
    댓글 쓰기
  3. Wooting 60HE Keycap Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, carefully extract debris from the exposed backboard of the keyboard.
    • Try to avoid the key nub, as it is lubricated, and outside contact can ruin it.
    댓글 쓰기
  4. Wooting 60HE Keycap Replacement: 4 단계, 이미지 1개 중 1개
    • Hold a multi-purpose electronics duster three inches away and at an angle from the exposed key.
    • Press the trigger in short bursts.
    • This will help get rid of any debris that you could not get from using your tweezers.
    댓글 쓰기
  5. Wooting 60HE Keycap Replacement: 5 단계, 이미지 2개 중 1개 Wooting 60HE Keycap Replacement: 5 단계, 이미지 2개 중 2개
    • Place a cotton swab on a napkin and lightly coat the head of the swab with 70% isopropyl alcohol.
    댓글 쓰기
  6. Wooting 60HE Keycap Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pat around the white backboard of the keyboard with the cotton swab.
    • This will help get rid of any built up residue, oils, or any possible spills that could have occurred in the past.
    • Isopropyl alcohol can strip the lubricant on the key, so put emphasis on dabbing the white backboard and not the key itself.
    댓글 쓰기
  7. Wooting 60HE Keycap Replacement: 7 단계, 이미지 3개 중 1개 Wooting 60HE Keycap Replacement: 7 단계, 이미지 3개 중 2개 Wooting 60HE Keycap Replacement: 7 단계, 이미지 3개 중 3개
    • Line the keycap in the upright position above the nub and press down lightly.
    • The key should slide back in place.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Aryav Balia
회원 가입일: 10/25/23
157 평판
안내서 1개를 작성함
CSU Los Angeles, Team 1-1, Briggs Fall 2023 CSU Los Angeles, Team 1-1, Briggs Fall 2023 회원
CSULA-BRIGGS-F23S1G1
6 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 45
전체 시간: 1,568
