주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
X230T RAM Replacement
필요한 것
  1. X230T RAM Replacement, Removing the battery: 1 단계, 이미지 1개 중 1개
    • Start by removing the battery from the laptop. The battery should be removed to prevent damaging the motherboard when the RAM is installed and removed.
    • Slide the latch on the left to the left, and hold the other latch on the right to the right.
    • Slide out the battery, it should come out effortlessly.
    댓글 쓰기
  2. X230T RAM Replacement, Removing the RAM cover: 2 단계, 이미지 1개 중 1개
    • Undo the two screws that are circled, then, pry the RAM cover off by placing your finger nail or a spudger between the laptop and the RAM cover and puling up.
    댓글 쓰기
  3. X230T RAM Replacement, Removing RAM: 3 단계, 이미지 3개 중 1개 X230T RAM Replacement, Removing RAM: 3 단계, 이미지 3개 중 2개 X230T RAM Replacement, Removing RAM: 3 단계, 이미지 3개 중 3개
    • Remove the two clips from the RAM by pulling them slowly in the direction shown by the red arrows. When both clips are released, the RAM will lift up at a 45 degree angle (picture 2).
    • Once the RAM is at the angle as shown in picture 2, remove the RAM by pulling it out of the computer, as shown by the orange arrow.
    • If required, repeat the procedure for the other RAM module. The steps are the same.
    댓글 쓰기
  4. X230T RAM Replacement, Installing RAM: 4 단계, 이미지 3개 중 1개 X230T RAM Replacement, Installing RAM: 4 단계, 이미지 3개 중 2개 X230T RAM Replacement, Installing RAM: 4 단계, 이미지 3개 중 3개
    • To install the RAM, insert the new RAM with the notch on the RAM lining up to the notch on the slot. Slide the RAM in on a 45 degree angle as shown in picture 1.
    • Firmly push down the RAM until it is locked in place by the clips on either side. The clips will move around the RAM when the RAM is being inserted.
    • Put on the cover with the clips going in to the bottom edge of the cover first, then, tighten up the screws on the RAM cover.
    • Install the battery in to the computer, making sure the locking clips are engaged, and power the computer on.
    • Check the BIOS or your operating system to verify the RAM is working.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
David Newberry
회원 가입일: 04/20/17
394 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 34
전체 시간: 1,391
