주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
XPS M2010 MXP061 Memory Module Replacement
필요한 것
  1. XPS M2010 MXP061 Memory Module Replacement, Memory Cover Remove: 1 단계, 이미지 1개 중 1개
    • CAUTION: Before you begin the following procedure, follow the safety instructions in the Product Information Guide .
    • NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface. If you leave the area, ground yourself again when you return to the computer.
    • NOTE: Memory modules purchased from Dell are covered under your computer warranty.
    • NOTE: To get maximum performance/dual-channel memory bandwidth capability, both memory module connectors must contain memory modules and the modules must be of the same size and configuration.
    • NOTICE: To help prevent damage to the system board, you must remove the main battery before you begin working inside the computer
    • With the computer still turned over, loosen the captive screw on the memory module cover and slide the cover toward the back of the computer to remove it.
    댓글 쓰기
  2. XPS M2010 MXP061 Memory Module Replacement, Removing Securing Clamps: 2 단계, 이미지 1개 중 1개
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    댓글 쓰기
  3. XPS M2010 MXP061 Memory Module Replacement, Removeing memory Module: 3 단계, 이미지 1개 중 1개
    • Remove the module from the connector on the system board.
    댓글 쓰기
  4. XPS M2010 MXP061 Memory Module Replacement, Replacing the Memory Module: 4 단계, 이미지 1개 중 1개
    • Align the notch on the edge of the memory module connector with the tab in the connector on the system board, and slide the module firmly into the connector at a 45-degree angle.
    댓글 쓰기
  5. XPS M2010 MXP061 Memory Module Replacement, Seating the Memory Module in place.: 5 단계, 이미지 1개 중 1개
    • Rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    댓글 쓰기
  6. XPS M2010 MXP061 Memory Module Replacement, Replace the memory cover: 6 단계, 이미지 1개 중 1개
    • Replace the memory cover. Align the notches in the cover with the tabs on the base, slide the cover toward the front of the computer, and tighten the captive screw.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
46,158 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 2,003개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 40
전체 시간: 612
