주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox 360 E CD Drive Replacement
필요한 것
    1. Xbox 360 E CD Drive Replacement, Top Panel: 1 단계, 이미지 1개 중 1개
      • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
      • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
      댓글 쓰기
    2. Xbox 360 E CD Drive Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
      • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
      댓글 쓰기
    3. Xbox 360 E CD Drive Replacement: 3 단계, 이미지 3개 중 1개 Xbox 360 E CD Drive Replacement: 3 단계, 이미지 3개 중 2개 Xbox 360 E CD Drive Replacement: 3 단계, 이미지 3개 중 3개
      • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
      • Pull the top panel off.
      댓글 쓰기
    1. Xbox 360 E CD Drive Replacement, Wi-Fi Card: 4 단계, 이미지 1개 중 1개
      • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
      댓글 쓰기
    2. Xbox 360 E CD Drive Replacement: 5 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement: 5 단계, 이미지 2개 중 2개
      • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
      댓글 쓰기
    1. Xbox 360 E CD Drive Replacement, Bottom Panel: 6 단계, 이미지 1개 중 1개
      • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
      • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
      댓글 쓰기
    2. Xbox 360 E CD Drive Replacement: 7 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement: 7 단계, 이미지 2개 중 2개
      • Slide the spudger along the crevice to separate the grated face and the top body.
      댓글 쓰기
    3. Xbox 360 E CD Drive Replacement: 8 단계, 이미지 3개 중 1개 Xbox 360 E CD Drive Replacement: 8 단계, 이미지 3개 중 2개 Xbox 360 E CD Drive Replacement: 8 단계, 이미지 3개 중 3개
      • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
      • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
      • Pull the bottom panel off.
      댓글 쓰기
    1. Xbox 360 E CD Drive Replacement, Top Body: 9 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement, Top Body: 9 단계, 이미지 2개 중 2개
      • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
      • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
      댓글 쓰기
    1. Xbox 360 E CD Drive Replacement, Bottom Body: 10 단계, 이미지 3개 중 1개 Xbox 360 E CD Drive Replacement, Bottom Body: 10 단계, 이미지 3개 중 2개 Xbox 360 E CD Drive Replacement, Bottom Body: 10 단계, 이미지 3개 중 3개
      • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
      • Lift the bottom body slightly away from the core at a 45 degree angle.
      댓글 쓰기
    2. Xbox 360 E CD Drive Replacement: 11 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement: 11 단계, 이미지 2개 중 2개
      • Rotate the Xbox so you are now looking at the back of the device.
      • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
      • Remove the sticker from the back of the Xbox.
      • The sticker is not needed for reassembly.
      댓글 쓰기
    3. Xbox 360 E CD Drive Replacement: 12 단계, 이미지 3개 중 1개 Xbox 360 E CD Drive Replacement: 12 단계, 이미지 3개 중 2개 Xbox 360 E CD Drive Replacement: 12 단계, 이미지 3개 중 3개
      • Turn the Xbox to the left to locate the clip holding the body together.
      • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
      댓글 쓰기
    4. Xbox 360 E CD Drive Replacement: 13 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement: 13 단계, 이미지 2개 중 2개
      • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
      댓글 쓰기
    1. Xbox 360 E CD Drive Replacement, CD Drive: 14 단계, 이미지 2개 중 1개 Xbox 360 E CD Drive Replacement, CD Drive: 14 단계, 이미지 2개 중 2개
      • Use your fingers to unplug the blue ribbon cable from the CD drive.
      댓글 쓰기
    2. Xbox 360 E CD Drive Replacement: 15 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers to unplug the blue and pink wires.
      댓글 쓰기
    3. Xbox 360 E CD Drive Replacement: 16 단계, 이미지 1개 중 1개
      • Lift the front end of the CD drive and take it out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 28명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
George
회원 가입일: 02/02/14
671 평판
안내서 1개를 작성함
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G11
4 회원들
안내서 66개를 작성함
12가이드 댓글
i wish the bottom cover magically came off like in step 9
sandjo - 답글 공유
screws are actually C1- C5 one is incorrectly labelled - C7 = C1 also in step 8.5 there are 3 clips holding back edge of bottom cover to top one. one on each end and one just to right of I/O area. can get 2 of them with a spudger (ends) and the middle one with a isesamo.
Andrew Boyd - 답글 공유
Several steps missing between 8 and 9
Freddie Parsons - 답글 공유
Like remove wifi adaptor.
william capewell - 답글 공유
There is some consistency errors in this guide. Step 9 seems to blast ahead beyond where we should be at this point of the guide.
Joe G. - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 83
지난 30일: 303
전체 시간: 28,047
