주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox 360 Wireless Controller Bottom Panel Replacement
필요한 것
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Battery: 1 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Depress the battery release button on the top of the controller.
      • Remove the battery holder from the controller.
      • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
      댓글 쓰기
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Rear Case: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
      댓글 쓰기
    2. Xbox 360 Wireless Controller Bottom Panel Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
      댓글 쓰기
    3. Xbox 360 Wireless Controller Bottom Panel Replacement: 4 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Spudger
      $2.99
      • Insert a Spudger between the front and rear cases along the left edge of the controller.
      • Rotate the spudger toward the front of the controller, prying the two cases apart.
      댓글 쓰기
    4. Xbox 360 Wireless Controller Bottom Panel Replacement: 5 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement: 5 단계, 이미지 2개 중 2개
      • Insert a spudger between the front and rear cases, near the headphone jack.
      • Rotate the spudger toward the front of the controller to pry the two cases apart.
      댓글 쓰기
    5. Xbox 360 Wireless Controller Bottom Panel Replacement: 6 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement: 6 단계, 이미지 2개 중 2개
      • Grasp the controller by the battery compartment and the headphone jack.
      • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
      • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
      댓글 쓰기
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Vibration Motors: 7 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement, Vibration Motors: 7 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
      • Lift the vibration motor out of the front case.
      댓글 쓰기
    2. Xbox 360 Wireless Controller Bottom Panel Replacement: 8 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the vibration motor from the other side of the controller using the same method previously described.
      • The left motor has significantly more counterweight than the right motor.
      댓글 쓰기
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Logic Board: 9 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement, Logic Board: 9 단계, 이미지 2개 중 2개
      • Lifting from the headphone jack and power plug, remove the logic board from the front case.
      댓글 쓰기
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Bottom Panel: 10 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement, Bottom Panel: 10 단계, 이미지 2개 중 2개
      • Lift the bumper panel off of the front case.
      댓글 쓰기
    2. Xbox 360 Wireless Controller Bottom Panel Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the rubber pad from the back of the D-pad.
      댓글 쓰기
    3. Xbox 360 Wireless Controller Bottom Panel Replacement: 12 단계, 이미지 1개 중 1개
      • Remove the two 7.0 mm silver Phillips screws from the back of the D-pad.
      댓글 쓰기
    4. Xbox 360 Wireless Controller Bottom Panel Replacement: 13 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement: 13 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • The D-pad is secured to its backing by two diagonal clips, shown in red.
      • Use a pair of tweezers and squeeze the clips together to release the D-pad from its backing.
      댓글 쓰기
    5. Xbox 360 Wireless Controller Bottom Panel Replacement: 14 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement: 14 단계, 이미지 2개 중 2개
      • Lift the D-pad backing out of its compartment on the front case.
      • The D-pad remains below the front case.
      • The D-pad will fall once its backing is removed. Be sure to support it as you remove the backing.
      • The backing is slotted to its compartment to ensure that it will always be aligned properly.
      댓글 쓰기
    6. Xbox 360 Wireless Controller Bottom Panel Replacement: 15 단계, 이미지 1개 중 1개
      • Remove the rubber pad from the back of the input buttons.
      댓글 쓰기
    7. Xbox 360 Wireless Controller Bottom Panel Replacement: 16 단계, 이미지 2개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement: 16 단계, 이미지 2개 중 2개
      • Using a pair or tweezers, remove the following buttons from the front panel:
      • A Button
      • B Button
      • X Button
      • Y Button
      • Start Button
      • Select Button
      • Guide Button
      댓글 쓰기
    8. Xbox 360 Wireless Controller Bottom Panel Replacement: 17 단계, 이미지 1개 중 1개
      • Using a pair of tweezers, remove the LED ring from the front panel.
      댓글 쓰기
    9. Xbox 360 Wireless Controller Bottom Panel Replacement: 18 단계, 이미지 3개 중 1개 Xbox 360 Wireless Controller Bottom Panel Replacement: 18 단계, 이미지 3개 중 2개 Xbox 360 Wireless Controller Bottom Panel Replacement: 18 단계, 이미지 3개 중 3개
      • Insert a spudger between the lower panel and front case.
      • Slide the spudger along the gap between the two case components.
      • Lift the lower panel off of the front case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
132,296 평판
안내서 144개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 47,681개를 작성함
2가이드 댓글
I have 2 remote controllers of X box one which is not working.
ravi.gopalakrishnan - 답글 공유
Ib rb button
Abdou Fegas - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 27
지난 30일: 100
전체 시간: 20,032
