주요 콘텐츠로 건너뛰기
Xbox Elite Wireless Controller Series 2 Battery Replacement
필요한 것
  1. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the thumbstick toppers: 1 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the thumbstick toppers: 1 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the thumbstick toppers: 1 단계, 이미지 3개 중 3개
    • Use your fingers to remove the thumbstick toppers.
  2. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the D-pad cover: 2 단계, 이미지 2개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the D-pad cover: 2 단계, 이미지 2개 중 2개
    • Use your fingers to remove the D-pad cover.
  3. Xbox Elite Wireless Controller Series 2 Battery Replacement, Disassembly information: 3 단계, 이미지 2개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Disassembly information: 3 단계, 이미지 2개 중 2개
    • The top housing is secured in two ways:
    • 13 tight plastic clips
    • Several strips of adhesive tape
  4. Xbox Elite Wireless Controller Series 2 Battery Replacement, Release the top housing clips: 4 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Release the top housing clips: 4 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Release the top housing clips: 4 단계, 이미지 3개 중 3개
    • Releasing the plastic clips requires significant force. Take your time to avoid damaging your controller.
    • Insert an opening tool between the left bumper and the top housing.
    • Pry up the top housing to release the top left clip.
  5. Xbox Elite Wireless Controller Series 2 Battery Replacement: 5 단계, 이미지 2개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Insert an opening tool into the seam between the two housings on the controller’s left edge.
  6. Xbox Elite Wireless Controller Series 2 Battery Replacement: 6 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement: 6 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the opening tool along the left edge and pry up intermittently to release the plastic clips.
  7. Xbox Elite Wireless Controller Series 2 Battery Replacement: 7 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement: 7 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Insert your opening tool into the seam between the two housings on the inner left edge.
    • Slide the opening tool along the bottom edge and pry up intermittently to release the plastic clips.
  8. Xbox Elite Wireless Controller Series 2 Battery Replacement: 8 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement: 8 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Insert your opening tool into the seam between the two housings on the controller’s right edge.
    • Slide the opening tool along the right edge and pry up intermittently to release the plastic clips.
  9. Xbox Elite Wireless Controller Series 2 Battery Replacement: 9 단계, 이미지 2개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Insert your opening tool between the right bumper and the top housing.
    • Pry up the top housing to release the remaining plastic clips.
  10. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the top housing: 10 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the top housing: 10 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the top housing: 10 단계, 이미지 3개 중 3개
    • Remove the top housing.
    • To reinstall the top housing, position it on the midframe assembly and press down firmly along the edges to engage all of the clips.
  11. Xbox Elite Wireless Controller Series 2 Battery Replacement, Unfasten the midframe assembly: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • If there's a white sticker covering one of the top screws, pierce through it with the screwdriver or use tweezers to remove it.
    • Use a Torx T8 Security screwdriver to remove the six 9 mm-long screws securing the midframe assembly.
    • Depending on the age and condition of your bit, a Torx T9 driver may fit better.
  12. Xbox Elite Wireless Controller Series 2 Battery Replacement, Pry up the midframe assembly: 12 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Pry up the midframe assembly: 12 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Pry up the midframe assembly: 12 단계, 이미지 3개 중 3개
    • The midframe assembly is held in place by three plastic clips and two metal rods.
    • Insert the flat end of a spudger under the top right edge of the midframe, just above the clip.
    • Pry up the midframe assembly to release the clips securing it.
  13. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the midframe assembly: 13 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the midframe assembly: 13 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the midframe assembly: 13 단계, 이미지 3개 중 3개
    • Remove the midframe assembly.
    • During reassembly, align the triggers with the bottom housing before clipping the midframe assembly back in. If they aren't lined up correctly, the triggers might not work properly.
    • To reinstall the midframe assembly, lay it into the bottom housing and press firmly on the edges to engage the clips.
  14. Xbox Elite Wireless Controller Series 2 Battery Replacement, Unfasten the battery cover: 14 단계, 이미지 1개 중 1개
    • Use a Torx T6 screwdriver to remove the four 6.9 mm-long screws securing the battery cover.
  15. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery cover: 15 단계, 이미지 2개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery cover: 15 단계, 이미지 2개 중 2개
    • Remove the battery cover.
  16. Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery: 16 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery: 16 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Battery Replacement, Remove the battery: 16 단계, 이미지 3개 중 3개
    • Grab the battery and lift it out of its recess.
    • Remove the battery.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • Make sure to align the battery correctly by positioning the contacts on the bottom right of the battery on the prongs.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Manuel Haeussermann
회원 가입일: 07/13/22
22,747 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
13가이드 댓글
Absolutely great tutorial, thank you. Now... any idea where I can get a replacement battery pack for this? Mine is deformed and unusable.
Kraeg Minett - 답글
Hi Kraeg Minett, thanks for your comment! Unfortunately, the battery is currently not available at the iFixit Store, but you might have some luck looking for a replacement battery by either using the model code for the Elite Wireless Controller (1797) or the battery itself (DYND01).
Manuel Haeussermann -
Hello.
Great tutorial
But - i cannot find replacement battery pack ( original one )
Please - can you help me with this issue ? Thank u
Stanislav Banas
Stanislav Baňas - 답글
I got one here - https://kasynparts.com/product/xbox-elit...
Had it shipped to the UK and it arrived today after two weeks. I haven't yet installed it as now waiting for a T6 driver to arrive but might be worth a try.
Captain Lager - 답글
Update - The repair was a success, the battery from the above website is good and the controller is now working again :)
Captain Lager -
댓글 쓰기
조회 통계:
지난 24시간: 34
지난 7일: 272
지난 30일: 1,158
전체 시간: 45,443
