주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox Fan Replacement
필요한 것
동영상 개요
    1. Xbox Fan Replacement, Fan Replacement: 1 단계, 이미지 1개 중 1개
      • Turn the Xbox on its back and remove the rubber feet in each corner using a flathead screwdriver.
      댓글 쓰기
    2. Xbox Fan Replacement: 2 단계, 이미지 1개 중 1개
      • Peel off the stickers on the bottom side of the Xbox and unscrew all six screws using a Torx 20 screwdriver bit. Set the screws off to the side so you don't misplace them.
      댓글 쓰기
    3. Xbox Fan Replacement: 3 단계, 이미지 1개 중 1개
      • Turn the console upright and remove the lid.
      • If you are having some trouble getting the lid off, try gently shaking the device while you pull up.
      댓글 쓰기
    4. Xbox Fan Replacement: 4 단계, 이미지 1개 중 1개
      • In order to remove the IDE cable, pull firmly on the cable straight back from the hard drive.
      • This may be slightly difficult; wiggling the cable back and forth will help to unfasten it.
      댓글 쓰기
    5. Xbox Fan Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the screw from underneath the IDE cable using a Torx 10 screwdriver.
      • This screw is located between the hard drive and DVD drive.
      댓글 쓰기
    6. Xbox Fan Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the hard drive by pulling it directly up and out of the case.
      • The hard drive is attached to a power cable, but you shouldn't need to remove the power cable to get the drive out unless you are replacing the hard drive.
      댓글 쓰기
    7. Xbox Fan Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the cable the same way that the hard drive cable was removed. Simply pull the cable straight out from the DVD drive.
      댓글 쓰기
    8. Xbox Fan Replacement: 8 단계, 이미지 2개 중 1개 Xbox Fan Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the screws from each end of the DVD drive using a Torx 10 screwdriver.
      댓글 쓰기
    9. Xbox Fan Replacement: 9 단계, 이미지 1개 중 1개
      • Once both screws have been removed pull straight upwards to remove the drive.
      댓글 쓰기
    10. Xbox Fan Replacement: 10 단계, 이미지 1개 중 1개
      • Unscrew all eleven screws that hold the mother board in place. Use a Torx 10 screwdriver to unscrew them.
      댓글 쓰기
    11. Xbox Fan Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the power cord by gently lifting it out at a 45 degree angle.
      • After the power cord is removed gently lift out the mother board by placing your fingers around the edges inside the case and lifting straight up and out.
      댓글 쓰기
    12. Xbox Fan Replacement: 12 단계, 이미지 1개 중 1개
      • Remove the old fan by pressing gently on the clips on each side with a flathead screwdriver and then carefully clip in a new fan.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Keiko McMaster
회원 가입일: 10/10/18
247 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 48
지난 30일: 234
전체 시간: 9,598
