주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Elite Controller (Model 1698) Disassembly
필요한 것
    1. Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: 1 단계, 이미지 2개 중 1개 Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: 1 단계, 이미지 2개 중 2개
      • You can remove the side panels with a pry tool.
      • You don't need to remove the rubber. The rubber on this controller was already bad.
      댓글 쓰기
    2. Xbox One Elite Controller (Model 1698) Disassembly, Removing the back panel screws: 2 단계, 이미지 1개 중 1개
      • Remove the 5 Torx Security Bit (TR9) screws.
      댓글 쓰기
    3. Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: 3 단계, 이미지 3개 중 1개 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: 3 단계, 이미지 3개 중 2개 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: 3 단계, 이미지 3개 중 3개
      • Pry the panel next to the 3.5mm port.
      • Be careful to not rip the ribbon shown in the next step.
      댓글 쓰기
    4. Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: 4 단계, 이미지 2개 중 1개 Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: 4 단계, 이미지 2개 중 2개
      • Be careful to not rip the ribbon cable.
      • You can pop the connector up to remove the ribbon easily.
      • Ribbon Cable
      댓글 쓰기
    5. Xbox One Elite Controller (Model 1698) Disassembly, Screws on controller motherboard: 5 단계, 이미지 1개 중 1개
      • Remove the 2 Torx (T6) screws.
      댓글 쓰기
    6. Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: 6 단계, 이미지 2개 중 1개 Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: 6 단계, 이미지 2개 중 2개
      • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
      댓글 쓰기
    7. Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: 7 단계, 이미지 2개 중 1개 Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: 7 단계, 이미지 2개 중 2개
      • Pull up from the "top" side of the controller on the daughterboard.
      댓글 쓰기
    1. Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: 8 단계, 이미지 3개 중 1개 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: 8 단계, 이미지 3개 중 2개 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: 8 단계, 이미지 3개 중 3개
      • Be Careful to not lose the sync button.
      • Pry the middle section up from the home button side.
      • This will also remove the LB and RB which is a single part.
      댓글 쓰기
    2. Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: 9 단계, 이미지 2개 중 1개 Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: 9 단계, 이미지 2개 중 2개
      • Unscrew the 6 Torx (T6) screws.
      댓글 쓰기
    1. Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: 10 단계, 이미지 2개 중 1개 Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: 10 단계, 이미지 2개 중 2개
      • Now you can remove the buttons themselves.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 45명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
EasyAsABC123
회원 가입일: 01/22/10
2,557 평판
안내서 5개를 작성함
14가이드 댓글
Is there any way I could just do step 8, removing the Home cover? I simply need to fix my USB port so i dont really wanna take it completely apart just for that.
jones_8515 - 답글 공유
Desoldering the rumble motors isn't necessary, nor is removing the first motherboard. Once you get that back panel off, you're golden.
J'Anthony Joseph - 답글 공유
Ya hi i opened my controller and right away i don’t see ether bolt in both handles. 4 i believe to top two bottom.
Suggestions please.
Craig Amyotte - 답글 공유
I found using a TQ5 for the 2 motherboard screws worked the best on my controller not a T6
Mat - 답글 공유
Thanks for the info
EasyAsABC123 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 42
지난 30일: 251
전체 시간: 105,227
