주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Kinect Colour Camera Replacement
필요한 것
  1. Xbox One Kinect Colour Camera Replacement, Outer Shell: 1 단계, 이미지 1개 중 1개
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
    댓글 쓰기
  2. Xbox One Kinect Colour Camera Replacement: 2 단계, 이미지 3개 중 1개 Xbox One Kinect Colour Camera Replacement: 2 단계, 이미지 3개 중 2개 Xbox One Kinect Colour Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
    댓글 쓰기
  3. Xbox One Kinect Colour Camera Replacement: 3 단계, 이미지 3개 중 1개 Xbox One Kinect Colour Camera Replacement: 3 단계, 이미지 3개 중 2개 Xbox One Kinect Colour Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
    댓글 쓰기
  4. Xbox One Kinect Colour Camera Replacement, Heat Sink Assembly: 4 단계, 이미지 2개 중 1개 Xbox One Kinect Colour Camera Replacement, Heat Sink Assembly: 4 단계, 이미지 2개 중 2개
    • Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
    • Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
    댓글 쓰기
  5. Xbox One Kinect Colour Camera Replacement: 5 단계, 이미지 3개 중 1개 Xbox One Kinect Colour Camera Replacement: 5 단계, 이미지 3개 중 2개 Xbox One Kinect Colour Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
    댓글 쓰기
  6. Xbox One Kinect Colour Camera Replacement: 6 단계, 이미지 3개 중 1개 Xbox One Kinect Colour Camera Replacement: 6 단계, 이미지 3개 중 2개 Xbox One Kinect Colour Camera Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Detach the ribbon cable leading to the microphone with the tweezers.
    • Remove the four 3.1x7.7 mm T9 screws connecting the microphone to the heat sink assembly.
    • Remove the stand.
    댓글 쓰기
  7. Xbox One Kinect Colour Camera Replacement: 7 단계, 이미지 3개 중 1개 Xbox One Kinect Colour Camera Replacement: 7 단계, 이미지 3개 중 2개 Xbox One Kinect Colour Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the eight 3.0x7.6 mm T9 screws from the motherboard.
    • Peel away the plastic film from the motherboard using the spudger.
    • Detach the ribbon cable leading to the color camera using the spudger.
    댓글 쓰기
  8. Xbox One Kinect Colour Camera Replacement: 8 단계, 이미지 3개 중 1개 Xbox One Kinect Colour Camera Replacement: 8 단계, 이미지 3개 중 2개 Xbox One Kinect Colour Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible.
    댓글 쓰기
  9. Xbox One Kinect Colour Camera Replacement, Colour Camera: 9 단계, 이미지 3개 중 1개 Xbox One Kinect Colour Camera Replacement, Colour Camera: 9 단계, 이미지 3개 중 2개 Xbox One Kinect Colour Camera Replacement, Colour Camera: 9 단계, 이미지 3개 중 3개
    • Go ahead and start by removing the Colour Camera's lens cap. This way you can remove the Camera without anything in your way.
    댓글 쓰기
  10. Xbox One Kinect Colour Camera Replacement: 10 단계, 이미지 2개 중 1개 Xbox One Kinect Colour Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Using the T5 screwdriver, remove the four 1.9x10.2 mm screws from the four corners of the camera.
    • With the spudger inserted in between the camera and the metal casing, carefully prop up the camera.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Malak Anshassi
회원 가입일: 09/22/14
356 평판
안내서 3개를 작성함
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G3
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 51
전체 시간: 2,281
