주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Optical/Disc Drive Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Xbox One Optical/Disc Drive Replacement, Side Vent: 1 단계, 이미지 3개 중 1개 Xbox One Optical/Disc Drive Replacement, Side Vent: 1 단계, 이미지 3개 중 2개 Xbox One Optical/Disc Drive Replacement, Side Vent: 1 단계, 이미지 3개 중 3개
    • With a plastic opening tool, pry the side vent from the console.
    • Start from the back edge and work towards the front of the console.
    댓글 쓰기
  2. Xbox One Optical/Disc Drive Replacement, Wi-Fi Board: 2 단계, 이미지 2개 중 1개 Xbox One Optical/Disc Drive Replacement, Wi-Fi Board: 2 단계, 이미지 2개 중 2개
    • Slide the black angled tab behind the silver button toward the back of the console and set it aside.
    댓글 쓰기
  3. Xbox One Optical/Disc Drive Replacement: 3 단계, 이미지 3개 중 1개 Xbox One Optical/Disc Drive Replacement: 3 단계, 이미지 3개 중 2개 Xbox One Optical/Disc Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Rotate the Xbox and remove the warranty sticker from the back. Removing this seal and opening the case of the Xbox voids your warranty with Microsoft.
    • Use a plastic opening tool on the back to pry the top of the case from the bottom. Use an up and out motion to dislodge the clips. There are multiple clips to release on the back and two on the sides.
    • This step may take up more time than the others, keep prying with the plastic opening tool and when you release one clip, wedge something underneath it so it doesn't close again.
    댓글 쓰기
  4. Xbox One Optical/Disc Drive Replacement: 4 단계, 이미지 2개 중 1개 Xbox One Optical/Disc Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully lift the top of the case, note that there is a wire connecting the front panel to the motherboard. Take care not to break this.
    • Using a spudger, release the ribbon wire from the front panel.
    • The top case is now free, set it aside.
    댓글 쓰기
  5. Xbox One Optical/Disc Drive Replacement: 5 단계, 이미지 3개 중 1개 Xbox One Optical/Disc Drive Replacement: 5 단계, 이미지 3개 중 2개 Xbox One Optical/Disc Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the speaker by squeezing the the tab on the black plastic mounting piece and lifting it up.
    • Carefully unplug the connector from the green front panel board.
    • The speaker is now free, set it aside.
    댓글 쓰기
  6. Xbox One Optical/Disc Drive Replacement: 6 단계, 이미지 2개 중 1개 Xbox One Optical/Disc Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the two 8.2mm T-9 screws securing the Wi-Fi board to the chassis.
    • Using the spudger, gently lift the antenna connector from the Wi-Fi board.
    댓글 쓰기
  7. Xbox One Optical/Disc Drive Replacement: 7 단계, 이미지 2개 중 1개 Xbox One Optical/Disc Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Using a spudger and a motion similar to the previous step, gently lift the antenna connector from the green board on the front.
    • Carefully pull out the clips securing the antenna wire to the chassis, releasing the wire.
    댓글 쓰기
  8. Xbox One Optical/Disc Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully pull the Wi-Fi board straight up to release it from the chassis. The Wi-Fi board is now free.
    댓글 쓰기
  9. Xbox One Optical/Disc Drive Replacement, Optical/Disc Drive: 9 단계, 이미지 2개 중 1개 Xbox One Optical/Disc Drive Replacement, Optical/Disc Drive: 9 단계, 이미지 2개 중 2개
    • Remove all eight of the 64.0 mm, T-9 screws labeled C1 through C8 securing the chassis top to the motherboard.
    댓글 쓰기
  10. Xbox One Optical/Disc Drive Replacement: 10 단계, 이미지 3개 중 1개 Xbox One Optical/Disc Drive Replacement: 10 단계, 이미지 3개 중 2개 Xbox One Optical/Disc Drive Replacement: 10 단계, 이미지 3개 중 3개
    • Lift the chassis top, being careful not to break the wire connecting the chassis top to the motherboard.
    • Unplug the connector labeled 3 on the motherboard by gently pulling up.
    • The chassis top is now free, set it aside.
    댓글 쓰기
  11. Xbox One Optical/Disc Drive Replacement: 11 단계, 이미지 3개 중 1개 Xbox One Optical/Disc Drive Replacement: 11 단계, 이미지 3개 중 2개 Xbox One Optical/Disc Drive Replacement: 11 단계, 이미지 3개 중 3개
    • Lift the bottom half of the chassis (motherboard and all) from the bottom half of the black case.
    • Unplug the red wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • Unplug the yellow wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • The optical drive is now free, lift it from the chassis and set it aside.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Gwendolyn Church
회원 가입일: 01/27/14
1,500 평판
안내서 6개를 작성함
Cal Poly, Team 6-22, Maness Winter 2014 Cal Poly, Team 6-22, Maness Winter 2014 회원
CPSU-MANESS-W14S6G22
4 회원들
안내서 11개를 작성함
7가이드 댓글
Are the drives paired as the 360 ones were do we need to swap over the logic board to get game playback? Thanks
Scott Mitchell - 답글 공유
Yes they are married in the same way as the 360 is. It's not difficult at all to swap.
Fred Haschalk - 답글 공유
The question is do we need to swap the pcb boards or can we plug in a replacement and play media?
ooozie - 답글 공유
The instructions are good up until you take the old drive out. There is nothing mentioned about switching cards on the drives.
David - 답글 공유
i cant do this im only a kid and my dad will get mad at me if I do this
laquantis jeffery - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 41
전체 시간: 17,475
