주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One S Optical Drive Assembly
필요한 것
  1. Xbox One S Optical Drive Assembly, Case: 1 단계, 이미지 1개 중 1개
    • Flip the Xbox One S so that the bottom of the case is facing upward.
    댓글 쓰기
  2. Xbox One S Optical Drive Assembly: 2 단계, 이미지 1개 중 1개
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    댓글 쓰기
  3. Xbox One S Optical Drive Assembly: 3 단계, 이미지 1개 중 1개
    • Once all of the clips are opened, remove the bottom part of the case.
    댓글 쓰기
  4. Xbox One S Optical Drive Assembly: 4 단계, 이미지 2개 중 1개 Xbox One S Optical Drive Assembly: 4 단계, 이미지 2개 중 2개
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    댓글 쓰기
  5. Xbox One S Optical Drive Assembly: 5 단계, 이미지 2개 중 1개 Xbox One S Optical Drive Assembly: 5 단계, 이미지 2개 중 2개
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
    댓글 쓰기
  6. Xbox One S Optical Drive Assembly, Interior Case Top Panel: 6 단계, 이미지 1개 중 1개
    • Flip the interior case so it is fan side upward.
    댓글 쓰기
  7. Xbox One S Optical Drive Assembly: 7 단계, 이미지 1개 중 1개
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
    댓글 쓰기
  8. Xbox One S Optical Drive Assembly, Hard Drive Assembly: 8 단계, 이미지 2개 중 1개 Xbox One S Optical Drive Assembly, Hard Drive Assembly: 8 단계, 이미지 2개 중 2개
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
    • Some models may require C4 and C5.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
    댓글 쓰기
  9. Xbox One S Optical Drive Assembly: 9 단계, 이미지 3개 중 1개 Xbox One S Optical Drive Assembly: 9 단계, 이미지 3개 중 2개 Xbox One S Optical Drive Assembly: 9 단계, 이미지 3개 중 3개
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    댓글 쓰기
  10. Xbox One S Optical Drive Assembly, Optical Drive Assembly: 10 단계, 이미지 1개 중 1개
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C4."
    댓글 쓰기
  11. Xbox One S Optical Drive Assembly: 11 단계, 이미지 1개 중 1개
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 22명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Victoria Law
회원 가입일: 04/26/17
1,126 평판
안내서 3개를 작성함
Cal Poly, Team S22-G3, Livingston Spring 2017 Cal Poly, Team S22-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G3
4 회원들
안내서 59개를 작성함
3가이드 댓글
alles schwachsinn: habe an meiner xbox one s dfas optische Laufwerk ausgetauscht ,da beim alten die spiele immer einfrohren .Alles nach Anleitung wie hier beschrieben . nun geht Garnichts mehr , kein bild kein ton geschweige noch ein spiel neu zu installiren .
siegfrieheide - 답글 공유
Das Problem ist, dass Microsoft das Laufwerk und die Hauptplatine “verheiratet" hat. Man kann also nur ein Laufwerk mitsamt der zugehörigen Hauptplatine austauschen.
VauWeh - 답글 공유
Muy bien explicado. Tengo un problema, ya que remplacé la unidad de disco, la consola prende y funciona, pero marca que hay error con la unidad, que puedo usar la consola peor no leer discos... Agradecería me pudieran orientar. Saludos
Rodolfo Alberto - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 39
지난 30일: 143
전체 시간: 13,281
