주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One S WiFi Card Replacement
필요한 것
  1. Xbox One S WiFi Card Replacement, Case: 1 단계, 이미지 1개 중 1개
    • Flip the Xbox One S so that the bottom of the case is facing upward.
    댓글 쓰기
  2. Xbox One S WiFi Card Replacement: 2 단계, 이미지 1개 중 1개
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    댓글 쓰기
  3. Xbox One S WiFi Card Replacement: 3 단계, 이미지 1개 중 1개
    • Once all of the clips are opened, remove the bottom part of the case.
    댓글 쓰기
  4. Xbox One S WiFi Card Replacement: 4 단계, 이미지 2개 중 1개 Xbox One S WiFi Card Replacement: 4 단계, 이미지 2개 중 2개
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    댓글 쓰기
  5. Xbox One S WiFi Card Replacement: 5 단계, 이미지 2개 중 1개 Xbox One S WiFi Card Replacement: 5 단계, 이미지 2개 중 2개
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
    댓글 쓰기
  6. Xbox One S WiFi Card Replacement, WiFi Card: 6 단계, 이미지 1개 중 1개
    • Search the sides of the interior case for the Wi-Fi card. It should be across from the hard drive.
    댓글 쓰기
  7. Xbox One S WiFi Card Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the black T8 screws with orange circles around them (there should be 3 of them).
    • After removing the screws, gently detach the Wi-Fi card.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 22명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Victoria Law
회원 가입일: 04/26/17
1,126 평판
안내서 3개를 작성함
Cal Poly, Team S22-G3, Livingston Spring 2017 Cal Poly, Team S22-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G3
4 회원들
안내서 59개를 작성함
5가이드 댓글
The T10 is too small for the WiFi card what should I use
Joe Smith - 답글 공유
T8 Torx Bit Screwdriver
Sebastian Rosso - 답글 공유
How long are the 15 mm screws supposed to be?
Natalie G - 답글 공유
15 mm long hense the name
Ethan Jones - 답글 공유
So I have replaced the Wi-Fi card from the Wi-Fi I bought from ifixit and my console cannot still connect to the Wi-Fi but my other devices can any help?
Noel Sappor - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 36
지난 30일: 195
전체 시간: 22,989
