주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Wi-Fi Board Replacement
필요한 것
  1. Xbox One Wi-Fi Board Replacement, Upper Case: 1 단계, 이미지 1개 중 1개
    댓글 쓰기
  2. Xbox One Wi-Fi Board Replacement: 2 단계, 이미지 2개 중 1개 Xbox One Wi-Fi Board Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port.
    • The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
    댓글 쓰기
  3. Xbox One Wi-Fi Board Replacement: 3 단계, 이미지 2개 중 1개 Xbox One Wi-Fi Board Replacement: 3 단계, 이미지 2개 중 2개
    • There is a small plastic tab that reinforces the front corner of the Xbox.
    • Slide the tab straight back and remove it.
    댓글 쓰기
  4. Xbox One Wi-Fi Board Replacement: 4 단계, 이미지 2개 중 1개 Xbox One Wi-Fi Board Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening.
    • There is a strong plastic clip connecting the two case halves (the first of many), so you'll need to use quite a bit of force.
    • Leave the spudger in place until you open the case completely. The clips are very springy and may cause the case to snap shut while you're working.
    댓글 쓰기
  5. Xbox One Wi-Fi Board Replacement: 5 단계, 이미지 2개 중 1개 Xbox One Wi-Fi Board Replacement: 5 단계, 이미지 2개 중 2개
    • The interface between the upper and lower cases is secured by several clips along the rear and remaining side of the Xbox.
    • Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
    댓글 쓰기
  6. Xbox One Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 1개 Xbox One Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 2개
    • Keep moving along the rear of the Xbox, prying up clips.
    • Make sure the spudger stays in its blocking position—even if the case opens up enough for the spudger to fall out, the remaining clips are springy and may pull the case completely shut. Keep the spudger in the gap to protect your progress.
    댓글 쓰기
  7. Xbox One Wi-Fi Board Replacement: 7 단계, 이미지 2개 중 1개 Xbox One Wi-Fi Board Replacement: 7 단계, 이미지 2개 중 2개
    • Keep popping clips. It may help to slide the plastic opening tool across the clips.
    • By the time you get to the far edge of the rear case, the top case should be ready to come off. If not, run your plastic opening tool around the corner and pop the clips along the side without the USB port.
    댓글 쓰기
  8. Xbox One Wi-Fi Board Replacement: 8 단계, 이미지 3개 중 1개 Xbox One Wi-Fi Board Replacement: 8 단계, 이미지 3개 중 2개 Xbox One Wi-Fi Board Replacement: 8 단계, 이미지 3개 중 3개
    • Starting with the spudger you left in the crack, pry the upper case up to free the last few clips.
    • Use a plastic opening tool to pop any straggler clips that weren't freed.
    • Do not try to remove the upper case yet, as it is still connected by the front panel button cable.
    • Lift the upper case slightly and shift it to give access to the front panel board.
    댓글 쓰기
  9. Xbox One Wi-Fi Board Replacement: 9 단계, 이미지 3개 중 1개 Xbox One Wi-Fi Board Replacement: 9 단계, 이미지 3개 중 2개 Xbox One Wi-Fi Board Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The front button cable has a unique ZIF connector—pay attention to the next few steps to safely disconnect it.
    • Use tweezers to lift the blue plastic retaining loop over the white connector on the board.
    • Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
    댓글 쓰기
  10. Xbox One Wi-Fi Board Replacement: 10 단계, 이미지 2개 중 1개 Xbox One Wi-Fi Board Replacement: 10 단계, 이미지 2개 중 2개
    • Use tweezers to pull the cable straight out of the connector on the board.
    • Remove the upper case.
    댓글 쓰기
  11. Xbox One Wi-Fi Board Replacement, Reassembly Instructions: 11 단계, 이미지 3개 중 1개 Xbox One Wi-Fi Board Replacement, Reassembly Instructions: 11 단계, 이미지 3개 중 2개 Xbox One Wi-Fi Board Replacement, Reassembly Instructions: 11 단계, 이미지 3개 중 3개
    • The next 4 steps are directions for reassembly. Skip them to continue with disassembly.
    • Use the flat end of a spudger to free the clips securing the front panel to the upper case.
    • Remove the front panel from the rest of the upper case.
    댓글 쓰기
  12. Xbox One Wi-Fi Board Replacement: 12 단계, 이미지 3개 중 1개 Xbox One Wi-Fi Board Replacement: 12 단계, 이미지 3개 중 2개 Xbox One Wi-Fi Board Replacement: 12 단계, 이미지 3개 중 3개
    • Replace the top part of the upper case.
    • Line up the clips and press firmly to re-seat them around the perimeter.
    댓글 쓰기
  13. Xbox One Wi-Fi Board Replacement: 13 단계, 이미지 3개 중 1개 Xbox One Wi-Fi Board Replacement: 13 단계, 이미지 3개 중 2개 Xbox One Wi-Fi Board Replacement: 13 단계, 이미지 3개 중 3개
    • Support the front panel near the front of the Xbox.
    • Use tweezers to replace the front button cable in its ZIF socket.
    • Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
    댓글 쓰기
  14. Xbox One Wi-Fi Board Replacement: 14 단계, 이미지 3개 중 1개 Xbox One Wi-Fi Board Replacement: 14 단계, 이미지 3개 중 2개 Xbox One Wi-Fi Board Replacement: 14 단계, 이미지 3개 중 3개
    • The lower edge of the front panel has plastic hooks that interlock with plastic hooks on the front edge of the lower case.
    • With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case.
    • Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
    댓글 쓰기
  15. Xbox One Wi-Fi Board Replacement, Wi-Fi Board: 15 단계, 이미지 1개 중 1개
    • Remove the two 9.5 mm T9 Torx screws from the WI-Fi board.
    댓글 쓰기
  16. Xbox One Wi-Fi Board Replacement: 16 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to disconnect the Wi-Fi antenna cable from its socket on the Wi-Fi board.
    댓글 쓰기
  17. Xbox One Wi-Fi Board Replacement: 17 단계, 이미지 1개 중 1개
    • Lift straight up on the W-Fi board to disconnect it from its connector and remove it from the Xbox.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 72명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
515,338 평판
안내서 407개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 30,155개를 작성함
53가이드 댓글
I think I'm going to try this. This would fix my: "I think there's a problem" error not being able scan for wifi, Id safely assume.
Stephen Erickson - 답글 공유
On top of that when I factory reset the box it gives me the error right away not even letting me bypass wireless connection and straight to hardwire.
Same here. Factory reset and made the system obsolete. Did you end up replacing the card and did it work?
Lightning Shaft - 답글 공유
Hi,
Did you managed to fix WiFi error with this method?
iminem - 답글 공유
has anyone figured this out?
Nicholas Everett - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 66
지난 30일: 378
전체 시간: 135,606
