주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
필요한 것
  1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: 1 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: 1 단계, 이미지 2개 중 2개
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
    댓글 쓰기
  2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 2 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 2 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    댓글 쓰기
  3. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 3 단계, 이미지 1개 중 1개
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    댓글 쓰기
  4. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 4 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 4 단계, 이미지 2개 중 2개
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
    댓글 쓰기
  5. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    댓글 쓰기
  6. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: 6 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: 6 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: 6 단계, 이미지 3개 중 3개
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 62명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Weston Gilmore
회원 가입일: 09/25/17
2,158 평판
안내서 1개를 작성함
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017 회원
CPSU-FORTE-F17S18G3
4 회원들
안내서 42개를 작성함
5가이드 댓글
i used a t8 and it worked
Rudy Bp - 답글 공유
T9 is VERY snug. T8 would probably be better but I don’t have one to try.
Craig Ferguson - 답글 공유
T9 barely fits, I couldn’t even get 2 of the screws to turn. I think T8 works better
Baron Kube - 답글 공유
One frustrating thing. All the guides I find on iFixit never give tips on reassembly. I'm having a difficult time getting the back plate back on. No help here, unfortunately.
Jim Pennington - 답글 공유
how to remove from ass
Mr Rump - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 111
지난 30일: 556
전체 시간: 37,710
