소개
Use this guide to replace a broken rear glass on your Xiaomi Mi10.
You’ll need replacement adhesive to reattach components when reassembling the device.
필요한 것
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
Insert the iFlex into the gap and leave it in place to prevent the adhesive from resealing.
Insert an opening pick into the gap you created with the iFlex.
Slide the opening pick to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right side to cut the remaining adhesive.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Secure the rear glass with pre-cut adhesive or double-sided adhesive tape during reassembly.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 3명이 해당 안내서를 완성하였습니다.
