주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Mi 8 Fingerprint Sensor Replacement
필요한 것
    1. Xiaomi Mi 8 Fingerprint Sensor Replacement, Rear Glass: 1 단계, 이미지 1개 중 1개
      • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
      댓글 쓰기
    2. Xiaomi Mi 8 Fingerprint Sensor Replacement: 2 단계, 이미지 3개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 2 단계, 이미지 3개 중 2개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 2 단계, 이미지 3개 중 3개
      • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
      • Insert an opening pick into the gap.
      • If the glass wont budge, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom right corner of the phone.
      댓글 쓰기
    3. Xiaomi Mi 8 Fingerprint Sensor Replacement: 3 단계, 이미지 2개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 3 단계, 이미지 2개 중 2개
      • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      댓글 쓰기
    4. Xiaomi Mi 8 Fingerprint Sensor Replacement: 4 단계, 이미지 3개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 4 단계, 이미지 3개 중 2개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 4 단계, 이미지 3개 중 3개
      • Insert a third opening pick at the bottom left corner.
      • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 8 to cut the adhesive.
      • Be aware of the fingerprint flex cable and only insert the tip of the opening pick. If insert to deep, you can cut the cable by accident.
      • As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      댓글 쓰기
    5. Xiaomi Mi 8 Fingerprint Sensor Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 5 단계, 이미지 2개 중 2개
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      댓글 쓰기
    6. Xiaomi Mi 8 Fingerprint Sensor Replacement: 6 단계, 이미지 2개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 6 단계, 이미지 2개 중 2개
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right edge to cut the remaining adhesive.
      • Don't try to remove the rear glass all the way yet. The fingerprint flex cable is still connected to the motherboard.
      댓글 쓰기
    7. Xiaomi Mi 8 Fingerprint Sensor Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 7 단계, 이미지 2개 중 2개
      • Carefully lift the rear glass and fold it to the left side to access the fingerprint flex connector.
      댓글 쓰기
    8. Xiaomi Mi 8 Fingerprint Sensor Replacement: 8 단계, 이미지 2개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 8 단계, 이미지 2개 중 2개
      • Use a spudger to pry up and disconnect the fingerprint flex cable.
      • Remove the rear glass.
      • Before installing new adhesive for reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      • After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond. A stack of heavy books on top of the phone works well.
      댓글 쓰기
    1. Xiaomi Mi 8 Fingerprint Sensor Replacement, Fingerprint Sensor: 9 단계, 이미지 1개 중 1개
      • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the fingerprint sensor. Apply the iOpener for at least two minutes.
      댓글 쓰기
    2. Xiaomi Mi 8 Fingerprint Sensor Replacement: 10 단계, 이미지 2개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 10 단계, 이미지 2개 중 2개
      • The fingerprint flex cable is mildly glued to the rear glass. Carefully slide an opening pick underneath to separate it from the glass.
      댓글 쓰기
    3. Xiaomi Mi 8 Fingerprint Sensor Replacement: 11 단계, 이미지 3개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 11 단계, 이미지 3개 중 2개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 11 단계, 이미지 3개 중 3개
      • Insert an opening pick under the top right corner of the fingerprint sensor.
      • Slide the opening pick along the top edge of the sensor to cut the adhesive.
      댓글 쓰기
    4. Xiaomi Mi 8 Fingerprint Sensor Replacement: 12 단계, 이미지 2개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 12 단계, 이미지 2개 중 2개
      • Slide the opening pick under the center of the sensor and twist it sideways to pry it up until you can get a good grip.
      댓글 쓰기
    5. Xiaomi Mi 8 Fingerprint Sensor Replacement: 13 단계, 이미지 2개 중 1개 Xiaomi Mi 8 Fingerprint Sensor Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the fingerprint sensor.
      댓글 쓰기
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
263,200 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 77,399개를 작성함
1가이드 댓글
This is so informative, one of my friend had this issue so I bought the replacement part followed this steps and its quiet easier to replace the flex cable.
harshithaemazel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 50
전체 시간: 3,551
