주요 콘텐츠로 건너뛰기
Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement
필요한 것
  1. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement, Rear Glass: 1 단계, 이미지 1/1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
  2. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 2 단계, 이미지 1/3 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 2 단계, 이미지 2/3 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 2 단계, 이미지 3/3
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner of the phone.
  3. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 3 단계, 이미지 1/2 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 3 단계, 이미지 2/2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 4 단계, 이미지 1/3 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 4 단계, 이미지 2/3 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 4 단계, 이미지 3/3
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 9 to cut the adhesive.
    • Be aware of the rear cameras and only insert the tip of the opening pick. As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 5 단계, 이미지 1/2 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 5 단계, 이미지 2/2
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 6 단계, 이미지 1/2 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 6 단계, 이미지 2/2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to cut the remaining adhesive.
  7. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 7 단계, 이미지 1/2 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 7 단계, 이미지 2/2
    • Carefully lift the rear glass and remove it.
    • Before installing new adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement, Motherboard Cover with Charging Coil: 8 단계, 이미지 1/1
    • Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
    • There might be tamper proof sticker on some of the screws.
  9. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 9 단계, 이미지 1/2 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 9 단계, 이미지 2/2
    • Insert an opening pick at the top right corner of the motherboard cover.
    • Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
  10. Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 10 단계, 이미지 1/2 Xiaomi Mi 9 Motherboard Cover with Charging Coil / NFC Replacement: 10 단계, 이미지 2/2
    • Carefully remove the motherboard cover including the charging coil / NFC antenna.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,353 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 2개
dove trovo il modulo nfc?
Angelo Panico - 답글
Como faço para comprar uma placa mãe dele 5521970811898
Mirogol - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 52
전체 시간: 3,683
