주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Mi Note Front camera Replacement
필요한 것
  1. Xiaomi Mi Note Front camera Replacement, Dual SIM SD Card: 1 단계, 이미지 1개 중 1개
    • Locate the hole for the Dual SIM SD card on the left side of the phone.
    댓글 쓰기
  2. Xiaomi Mi Note Front camera Replacement: 2 단계, 이미지 2개 중 1개 Xiaomi Mi Note Front camera Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
    댓글 쓰기
  3. Xiaomi Mi Note Front camera Replacement, Battery: 3 단계, 이미지 2개 중 1개 Xiaomi Mi Note Front camera Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
    댓글 쓰기
  4. Xiaomi Mi Note Front camera Replacement: 4 단계, 이미지 3개 중 1개 Xiaomi Mi Note Front camera Replacement: 4 단계, 이미지 3개 중 2개 Xiaomi Mi Note Front camera Replacement: 4 단계, 이미지 3개 중 3개
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
    댓글 쓰기
  5. Xiaomi Mi Note Front camera Replacement: 5 단계, 이미지 1개 중 1개
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
    댓글 쓰기
  6. Xiaomi Mi Note Front camera Replacement: 6 단계, 이미지 2개 중 1개 Xiaomi Mi Note Front camera Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
    댓글 쓰기
  7. Xiaomi Mi Note Front camera Replacement, Front camera: 7 단계, 이미지 1개 중 1개
    • Use a spudger to pry upwards and detach the three ribbons that are connected to the motherboard.
    댓글 쓰기
  8. Xiaomi Mi Note Front camera Replacement: 8 단계, 이미지 2개 중 1개 Xiaomi Mi Note Front camera Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
    • You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
    • When detaching the ribbon on the left use minimal force to prevent damage.
    댓글 쓰기
  9. Xiaomi Mi Note Front camera Replacement: 9 단계, 이미지 2개 중 1개 Xiaomi Mi Note Front camera Replacement: 9 단계, 이미지 2개 중 2개
    • Use a tweezer to lift and remove the motherboard from the frame.
    • Be sure that the Dual SIM card and tray has been removed.
    댓글 쓰기
  10. Xiaomi Mi Note Front camera Replacement: 10 단계, 이미지 1개 중 1개
    • The front camera is attached to the motherboard by a ribbon, use tweezers to detach it from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Abdulaziz Aldekheel
회원 가입일: 09/03/15
374 평판
안내서 2개를 작성함
USF Tampa, Team 1-6, Sullivan Fall 2015 USF Tampa, Team 1-6, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G6
4 회원들
안내서 18개를 작성함
1가이드 댓글
Telefonumu 2 hafta önce suya düşürdüm ilk etapta açılmadı ama şimdi açılıyor ama kamera çalışmıyor ön kamera Bir de hoparlörü boğuk çıkıyor tamir etsene
Kaan Guney - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 23
전체 시간: 3,001
