주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Mi Note Rear camera Replacement
필요한 것
  1. Xiaomi Mi Note Rear camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 Xiaomi Mi Note Rear camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
    댓글 쓰기
  2. Xiaomi Mi Note Rear camera Replacement: 2 단계, 이미지 3개 중 1개 Xiaomi Mi Note Rear camera Replacement: 2 단계, 이미지 3개 중 2개 Xiaomi Mi Note Rear camera Replacement: 2 단계, 이미지 3개 중 3개
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
    댓글 쓰기
  3. Xiaomi Mi Note Rear camera Replacement: 3 단계, 이미지 1개 중 1개
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
    댓글 쓰기
  4. Xiaomi Mi Note Rear camera Replacement: 4 단계, 이미지 2개 중 1개 Xiaomi Mi Note Rear camera Replacement: 4 단계, 이미지 2개 중 2개
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
    댓글 쓰기
  5. Xiaomi Mi Note Rear camera Replacement, Rear camera: 5 단계, 이미지 1개 중 1개
    • Use a plastic spudger to detach the remaining ribbon from the motherboard.
    댓글 쓰기
  6. Xiaomi Mi Note Rear camera Replacement: 6 단계, 이미지 2개 중 1개 Xiaomi Mi Note Rear camera Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to detach the small ribbon on the left side located near the volume buttons as well as the microphone cord located on the right side along the frame.
    • When detaching the ribbon on the left use minimal force to prevent damage.
    댓글 쓰기
  7. Xiaomi Mi Note Rear camera Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Mi Note Rear camera Replacement: 7 단계, 이미지 2개 중 2개
    • Use a tweezer to lift and remove the motherboard from the frame.
    • Be sure that the Dual SIM card and tray has been removed.
    댓글 쓰기
  8. Xiaomi Mi Note Rear camera Replacement: 8 단계, 이미지 1개 중 1개
    • Use tweezers to slide the ribbon to the right out of the insert as shown in the image.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Abdulaziz Aldekheel
회원 가입일: 09/03/15
374 평판
안내서 2개를 작성함
USF Tampa, Team 1-6, Sullivan Fall 2015 USF Tampa, Team 1-6, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G6
4 회원들
안내서 18개를 작성함
1가이드 댓글
With the onset of the new year, the world of smartphones is looking forward to the launch of Xiaomi Mi6, the next flagship launch in the series of Mi phones.
The Mi 5 received a lot of positive feedback when it launched last year, so we can expect that the Mi6 is going to be even better than its predecessor.
You can check out my site http://mi6splus.com/xiaomi-mi-6-features... for more info about the same.
Rick Halder - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 4,840
