주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Redmi Note Charging Port Replacement
필요한 것
    1. Xiaomi Redmi Note Charging Port Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
      • Insert the plastic opening tool between the charging port and the rear case.
      • Pry the end of the rear case up from the charging port.
      댓글 쓰기
    2. Xiaomi Redmi Note Charging Port Replacement: 2 단계, 이미지 2개 중 1개 Xiaomi Redmi Note Charging Port Replacement: 2 단계, 이미지 2개 중 2개
      • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
      댓글 쓰기
    3. Xiaomi Redmi Note Charging Port Replacement: 3 단계, 이미지 2개 중 1개 Xiaomi Redmi Note Charging Port Replacement: 3 단계, 이미지 2개 중 2개
      • Locate the indentation at the bottom of the battery.
      • Place a finger in the indentation and lift up to remove the battery.
      댓글 쓰기
    1. Xiaomi Redmi Note Charging Port Replacement, Midframe: 4 단계, 이미지 2개 중 1개 Xiaomi Redmi Note Charging Port Replacement, Midframe: 4 단계, 이미지 2개 중 2개
      • Remove twelve 3.5mm Phillips #00 screws from the midframe.
      댓글 쓰기
    2. Xiaomi Redmi Note Charging Port Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Redmi Note Charging Port Replacement: 5 단계, 이미지 2개 중 2개
      • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
      • Run the plastic opening tool along the seam.
      • Pry up the midframe with the plastic opening tool.
      • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
      • There will be snapping sounds as the clips on the midframe disconnect from the phone.
      댓글 쓰기
    1. Xiaomi Redmi Note Charging Port Replacement, Charging Port: 6 단계, 이미지 2개 중 1개 Xiaomi Redmi Note Charging Port Replacement, Charging Port: 6 단계, 이미지 2개 중 2개
      • Locate the charging port panel at the bottom of the device.
      • Remove the 2.9 mm Phillips #00 screws on the sides of the panel.
      댓글 쓰기
    2. Xiaomi Redmi Note Charging Port Replacement: 7 단계, 이미지 3개 중 1개 Xiaomi Redmi Note Charging Port Replacement: 7 단계, 이미지 3개 중 2개 Xiaomi Redmi Note Charging Port Replacement: 7 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Locate the antenna cable at the top right corner of the charging port.
      • Lift the antenna cable off of the panel with tweezers.
      댓글 쓰기
    3. Xiaomi Redmi Note Charging Port Replacement: 8 단계, 이미지 3개 중 1개 Xiaomi Redmi Note Charging Port Replacement: 8 단계, 이미지 3개 중 2개 Xiaomi Redmi Note Charging Port Replacement: 8 단계, 이미지 3개 중 3개
      • Flip the panel to its back side, but do not fully lift it off of the phone yet.
      • Use a plastic opening tool to gently pry off the press fit connector attached to the back side of the panel.
      댓글 쓰기
    4. Xiaomi Redmi Note Charging Port Replacement: 9 단계, 이미지 1개 중 1개
      • Lift the charging port up to remove it from the frame.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 26명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Caitlin Settles
회원 가입일: 04/26/17
789 평판
안내서 2개를 작성함
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G4
4 회원들
안내서 32개를 작성함
9가이드 댓글
Hi, should the battery have a certain time of charge after replacement? Or just start using like everyday, charge when needed?
Luis Amaral - 답글 공유
Hi Caitlin, do you know where I can purchase an OEM Charging Port? All I can find is non OEM parts on eBay and parts on witrig. I looked into that site, and it has awful reviews, so I’m not going to try it.
ilikechocobo - 답글 공유
hi where can i buy the replacement port charger for the xioami note boo pease
View similar itemsItem - Xiaomi Mi Pad 3 Tablet PC 7.9'' MIUI 8 2.1GHz MT8176 Hexa Core 4GB+64GB WiFi
Brigitte Berkaine-Tongue - 답글 공유
How much is it to repair in Qatar riyal
Cynthia - 답글 공유
How much does it cost to repair the charging port in Qatar royals?
Cynthia - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 40
지난 30일: 178
전체 시간: 43,062
