주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
XtremeMac Luna LCD Display Replacement
필요한 것
    1. XtremeMac Luna LCD Display Replacement, Bottom Panel: 1 단계, 이미지 3개 중 1개 XtremeMac Luna LCD Display Replacement, Bottom Panel: 1 단계, 이미지 3개 중 2개 XtremeMac Luna LCD Display Replacement, Bottom Panel: 1 단계, 이미지 3개 중 3개
      • Flip the device over so that the batteries are closest to you.
      • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
      • Push the battery against the spring and lift it out of the casing.
      • Repeat with the other battery.
      댓글 쓰기
    2. XtremeMac Luna LCD Display Replacement: 2 단계, 이미지 1개 중 1개
      • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
      • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
      댓글 쓰기
    3. XtremeMac Luna LCD Display Replacement: 3 단계, 이미지 2개 중 1개 XtremeMac Luna LCD Display Replacement: 3 단계, 이미지 2개 중 2개
      • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
      • Gently tilt the lid back 45 degrees so that the inside is exposed.
      • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
      댓글 쓰기
    1. XtremeMac Luna LCD Display Replacement, Dock Circuit Board: 4 단계, 이미지 3개 중 1개 XtremeMac Luna LCD Display Replacement, Dock Circuit Board: 4 단계, 이미지 3개 중 2개 XtremeMac Luna LCD Display Replacement, Dock Circuit Board: 4 단계, 이미지 3개 중 3개
      • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
      댓글 쓰기
    1. XtremeMac Luna LCD Display Replacement, Button Circuit Boards: 5 단계, 이미지 2개 중 1개 XtremeMac Luna LCD Display Replacement, Button Circuit Boards: 5 단계, 이미지 2개 중 2개
      • Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
      • Removing the right circuit board first will make it easier to unscrew the left because the heat-sinks on the left circuit board can get in the way of the screwdriver.
      댓글 쓰기
    2. XtremeMac Luna LCD Display Replacement: 6 단계, 이미지 3개 중 1개 XtremeMac Luna LCD Display Replacement: 6 단계, 이미지 3개 중 2개 XtremeMac Luna LCD Display Replacement: 6 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to pry the black connections away from the top casing.
      • Be attentive when you separate the circuit boards from the top, as there is a loose wheel inside.
      댓글 쓰기
    3. XtremeMac Luna LCD Display Replacement: 7 단계, 이미지 2개 중 1개 XtremeMac Luna LCD Display Replacement: 7 단계, 이미지 2개 중 2개
      • Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
      • The glue that holds the connection together will come off when you pull. Pull on the tab with enough force to break the glue without damaging the wires.
      댓글 쓰기
    1. XtremeMac Luna LCD Display Replacement, Speakers: 8 단계, 이미지 2개 중 1개 XtremeMac Luna LCD Display Replacement, Speakers: 8 단계, 이미지 2개 중 2개
      • Unscrew four 7mm Phillips screws from the base of each speaker unit.
      댓글 쓰기
    2. XtremeMac Luna LCD Display Replacement: 9 단계, 이미지 3개 중 1개 XtremeMac Luna LCD Display Replacement: 9 단계, 이미지 3개 중 2개 XtremeMac Luna LCD Display Replacement: 9 단계, 이미지 3개 중 3개
      • Lift the speakers up out of the Luna chassis.
      댓글 쓰기
    1. XtremeMac Luna LCD Display Replacement, LCD Display: 10 단계, 이미지 2개 중 1개 XtremeMac Luna LCD Display Replacement, LCD Display: 10 단계, 이미지 2개 중 2개
      • Unscrew two 10mm silver screws at the base of the LCD screen to free it from the chassis.
      댓글 쓰기
    2. XtremeMac Luna LCD Display Replacement: 11 단계, 이미지 2개 중 1개 XtremeMac Luna LCD Display Replacement: 11 단계, 이미지 2개 중 2개
      • Gently pull up on the LCD screen to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Matt Ducasse
회원 가입일: 04/18/13
12 평판
안내서 3개를 작성함
Cal Poly, Team 3-47, Amido Spring 2013 Cal Poly, Team 3-47, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G47
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 30
전체 시간: 713
