주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Yuneec Breeze 4K Camera Replacement
필요한 것
    1. Yuneec Breeze 4K Camera Replacement, Camera: 1 단계, 이미지 2개 중 1개 Yuneec Breeze 4K Camera Replacement, Camera: 1 단계, 이미지 2개 중 2개
      • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
      • Once the battery is taken out, flip over the drone so that the cameras are now facing up.
      댓글 쓰기
    2. Yuneec Breeze 4K Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Using small pliers grip the connector of the wire and pull it out slowly.
      댓글 쓰기
    3. Yuneec Breeze 4K Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the four white rubber dampeners located in each corner of the frame that hold the it in place.
      댓글 쓰기
    4. Yuneec Breeze 4K Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Unplug the two vertical plugs located in the rear of the M7 board.
      댓글 쓰기
    5. Yuneec Breeze 4K Camera Replacement: 5 단계, 이미지 1개 중 1개
      • Slightly lift the M7 board to remove the two plugs located under the rear of the board.
      댓글 쓰기
    6. Yuneec Breeze 4K Camera Replacement: 6 단계, 이미지 1개 중 1개
      • Once all plugs on top of the M7 board are disconnected, carefully lift the M7 board onto its side and remove all plugs on the bottom.
      댓글 쓰기
    7. Yuneec Breeze 4K Camera Replacement: 7 단계, 이미지 2개 중 1개 Yuneec Breeze 4K Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Tilt the M7 board onto its side. Using the Phillips #00 screwdriver remove the two black screws connected to the large black two pronged input.
      댓글 쓰기
    8. Yuneec Breeze 4K Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Using a pair of pliers pull apart the battery connector.
      댓글 쓰기
    9. Yuneec Breeze 4K Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Flip over the entire frame along with the M7 board and the A9 board.
      댓글 쓰기
    10. Yuneec Breeze 4K Camera Replacement: 10 단계, 이미지 1개 중 1개
      • There will be 4 screws that hold the A9 board together. Using a H1.5 Alan bit unscrew those bolts to take the A9 board apart.
      댓글 쓰기
    11. Yuneec Breeze 4K Camera Replacement: 11 단계, 이미지 1개 중 1개
      • Unplug the only wire that is connected to the A9 board.
      댓글 쓰기
    12. Yuneec Breeze 4K Camera Replacement: 12 단계, 이미지 1개 중 1개
      • Pull apart the frame from the other board. The camera will be connected by a plug and it should pull out easily.
      댓글 쓰기
    13. Yuneec Breeze 4K Camera Replacement: 13 단계, 이미지 1개 중 1개
      • Unscrew the four screws that are holding the camera to the frame.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Wes Knutson
회원 가입일: 10/04/18
481 평판
안내서 3개를 작성함
UW Stout, Team S6-G5, Ogden Fall 2018 UW Stout, Team S6-G5, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G5
4 회원들
안내서 4개를 작성함
1가이드 댓글
Excellent! I don’t think that the process could of have been any more clear than this.
neonjohn25 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 36
전체 시간: 2,429
