주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Yuneec Typhoon H Plus Arm Replacement
필요한 것
    1. Yuneec Typhoon H Plus Arm Replacement, Motor: 1 단계, 이미지 2개 중 1개 Yuneec Typhoon H Plus Arm Replacement, Motor: 1 단계, 이미지 2개 중 2개
      • Flip the drone over so the bottom is facing upwards.
      • Remove ten 9.5mm Hex 2 screws attached to the bottom shell.
      댓글 쓰기
    2. Yuneec Typhoon H Plus Arm Replacement: 2 단계, 이미지 3개 중 1개 Yuneec Typhoon H Plus Arm Replacement: 2 단계, 이미지 3개 중 2개 Yuneec Typhoon H Plus Arm Replacement: 2 단계, 이미지 3개 중 3개
      • Carefully detach the top billit piece from the drone. There are internal clips that need to be detached from the top piece in order for the entire unit to come off.
      • Once the lid is off, detach the wire that holds the lid to the body. Press down on the clip and slide the wire out.
      댓글 쓰기
    3. Yuneec Typhoon H Plus Arm Replacement: 3 단계, 이미지 3개 중 1개 Yuneec Typhoon H Plus Arm Replacement: 3 단계, 이미지 3개 중 2개 Yuneec Typhoon H Plus Arm Replacement: 3 단계, 이미지 3개 중 3개
      • Find the base of the arm you are replacing and remove the electrical tape.
      • Disconnect the red, black, and blue wires. Also disconnect the white clip that is associated with those same wires.
      • You may need a pair of pliers to get enough grip to disconnect the three wires.
      댓글 쓰기
    4. Yuneec Typhoon H Plus Arm Replacement: 4 단계, 이미지 3개 중 1개 Yuneec Typhoon H Plus Arm Replacement: 4 단계, 이미지 3개 중 2개 Yuneec Typhoon H Plus Arm Replacement: 4 단계, 이미지 3개 중 3개
      • Find the pin that holds the arm by pulling down the bottom shell. Use a Hex bit 2 screwdriver to remove it
      • After removing the pin, pull the arm and wires out of the drone.
      댓글 쓰기
    5. Yuneec Typhoon H Plus Arm Replacement: 5 단계, 이미지 2개 중 1개 Yuneec Typhoon H Plus Arm Replacement: 5 단계, 이미지 2개 중 2개
      • Use the wrench tool from the Yuneec drone box to remove the bottom cap from the motor mount. Twist clockwise until it pops; then it will slide out easily.
      댓글 쓰기
    6. Yuneec Typhoon H Plus Arm Replacement: 6 단계, 이미지 2개 중 1개 Yuneec Typhoon H Plus Arm Replacement: 6 단계, 이미지 2개 중 2개
      • Disconnect the electrical board from the wire and thread the clip through the arm to the side with the motor to remove the entire motor/wire assembly.
      • After both sides of the wire are on the side with the motor, pull the wires through the length of the arm.
      댓글 쓰기
    1. Yuneec Typhoon H Plus Arm Replacement, Arm: 7 단계, 이미지 3개 중 1개 Yuneec Typhoon H Plus Arm Replacement, Arm: 7 단계, 이미지 3개 중 2개 Yuneec Typhoon H Plus Arm Replacement, Arm: 7 단계, 이미지 3개 중 3개
      • Remove the small Phillips #000 screw that holds the arm clip in place.
      • Use iFixit's metal spudger to pry up on the clip to release it from the arm and pull it out with your fingers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Theron Dale
회원 가입일: 01/23/20
109 평판
안내서 1개를 작성함
Cal Poly, Team S2-G1, White Winter 2020 Cal Poly, Team S2-G1, White Winter 2020 회원
CPSU-WHITE-W20S2G1
4 회원들
안내서 5개를 작성함
1가이드 댓글
Would this be the same process for the Yuneec H520?
Reon Sharp - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 11
지난 30일: 37
전체 시간: 1,220
