주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZCWA BR151 Sprayer/Pump Replacement
필요한 것
    1. ZCWA BR151 Sprayer/Pump Replacement, Water Tank: 1 단계, 이미지 1개 중 1개
      • Turn off the device.
      댓글 쓰기
    2. ZCWA BR151 Sprayer/Pump Replacement: 2 단계, 이미지 2개 중 1개 ZCWA BR151 Sprayer/Pump Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
      • Pull it out.
      댓글 쓰기
    1. ZCWA BR151 Sprayer/Pump Replacement, Sprayer/Pump: 3 단계, 이미지 2개 중 1개 ZCWA BR151 Sprayer/Pump Replacement, Sprayer/Pump: 3 단계, 이미지 2개 중 2개
      • Flip the device over to access the bottom panel.
      • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
      • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
      댓글 쓰기
    2. ZCWA BR151 Sprayer/Pump Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
      • Remove the bumper guards by lifting them.
      댓글 쓰기
    3. ZCWA BR151 Sprayer/Pump Replacement: 5 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
      댓글 쓰기
    4. ZCWA BR151 Sprayer/Pump Replacement: 6 단계, 이미지 2개 중 1개 ZCWA BR151 Sprayer/Pump Replacement: 6 단계, 이미지 2개 중 2개
      • Carefully lift the bottom panel off of the top.
      • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
      • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
      댓글 쓰기
    5. ZCWA BR151 Sprayer/Pump Replacement: 7 단계, 이미지 1개 중 1개
      • Though optional, we recommend separating the top and bottom panels for easy access to the sprayer/pump.
      • Pinch the wire bracket that is on the top panel while pulling the bracket away.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      댓글 쓰기
    6. ZCWA BR151 Sprayer/Pump Replacement: 8 단계, 이미지 3개 중 1개 ZCWA BR151 Sprayer/Pump Replacement: 8 단계, 이미지 3개 중 2개 ZCWA BR151 Sprayer/Pump Replacement: 8 단계, 이미지 3개 중 3개
      • The sprayer is slotted in place with grooves. Slide up the sprayer by lifting it up with your fingers.
      • The sprayer/pump should loosely be free, except for wires connecting it to the motherboard.
      댓글 쓰기
    7. ZCWA BR151 Sprayer/Pump Replacement: 9 단계, 이미지 3개 중 1개 ZCWA BR151 Sprayer/Pump Replacement: 9 단계, 이미지 3개 중 2개 ZCWA BR151 Sprayer/Pump Replacement: 9 단계, 이미지 3개 중 3개
      • Turn the device around so that the motherboard is closest to you.
      • Track the red and black wire cables from the sprayer/pump to the motherboard.
      • Remove the sprayer/pump wiring from the port on the motherboard by pinching the silver brackets and pull the wire casing away from the motherboard.
      • Remove the sprayer/pump from the vacuum.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Gavin H. Stackhouse
회원 가입일: 01/31/24
399 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 27
전체 시간: 1,113
