주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZCWA BR151 Wheel Replacement
필요한 것
  1. ZCWA BR151 Wheel Replacement, Water Tank: 1 단계, 이미지 1개 중 1개
    • Turn off the device.
    댓글 쓰기
  2. ZCWA BR151 Wheel Replacement: 2 단계, 이미지 2개 중 1개 ZCWA BR151 Wheel Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
    댓글 쓰기
  3. ZCWA BR151 Wheel Replacement, Wheel: 3 단계, 이미지 2개 중 1개 ZCWA BR151 Wheel Replacement, Wheel: 3 단계, 이미지 2개 중 2개
    • Flip the device over to access the bottom panel.
    • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
    • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
    댓글 쓰기
  4. ZCWA BR151 Wheel Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
    • Remove the bumper guards by lifting them.
    댓글 쓰기
  5. ZCWA BR151 Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
    댓글 쓰기
  6. ZCWA BR151 Wheel Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove three 8 mm screws from the wheel plate.
    댓글 쓰기
  7. ZCWA BR151 Wheel Replacement: 7 단계, 이미지 2개 중 1개 ZCWA BR151 Wheel Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully lift the bottom panel off of the top.
    • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
    • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
    댓글 쓰기
  8. ZCWA BR151 Wheel Replacement: 8 단계, 이미지 1개 중 1개
    • Though optional, we recommend separating the top and bottom panels for easy access to the wheels.
    • Pinch the wire bracket that is on the top panel while pulling the bracket away.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    댓글 쓰기
  9. ZCWA BR151 Wheel Replacement: 9 단계, 이미지 3개 중 1개 ZCWA BR151 Wheel Replacement: 9 단계, 이미지 3개 중 2개 ZCWA BR151 Wheel Replacement: 9 단계, 이미지 3개 중 3개
    • Using a Phillips #1 screwdriver, remove the single screw to the spring.
    • Once the spring is unscrewed, slowly pull it towards you, then to the left of the spring bracket to free the spring.
    댓글 쓰기
  10. ZCWA BR151 Wheel Replacement: 10 단계, 이미지 2개 중 1개 ZCWA BR151 Wheel Replacement: 10 단계, 이미지 2개 중 2개
    • The wheel's motor is still attached to the motherboard of the device. Locate the wheel's wiring and the port connector on the motherboard.
    • Pinch the silver brackets and pull the wire casing away from the motherboard.
    • Remove the wheel from the vacuum.
    • Repeat Steps 6-10 to replace the wheel on the opposite side.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Gavin H. Stackhouse
회원 가입일: 01/31/24
399 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 16
지난 30일: 67
전체 시간: 1,110
