소개
If the battery on your ZTE Blade X Max is faulty—short battery life, failure to power on, powering off before reaching 0%—and you have already been through our troubleshooting guide, then you will have to replace the battery.
This guide requires removing the back of the phone. You will have to use heating products to complete this guide. If you are using the iFixit iOpener, or a heating pad, be sure to follow the instructions for that particular product.
To remove the battery, you will have to heat the phone. Be sure not to overheat the battery. If you do, the battery will swell and be rendered useless.
필요한 것
Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
Use the iOpener or heating pad to heat the phone. This will loosen the adhesive below the battery.
다른 한 분이 해당 안내서를 완성하였습니다.
