주요 콘텐츠로 건너뛰기
ZTE Boost MAX N9520 Battery Replacement
필요한 것
  1. ZTE Boost MAX N9520 Battery Replacement, Battery: 1 단계, 이미지 1/2 ZTE Boost MAX N9520 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • First, remove the microSD tray, use a sim ejector tool for this.
    • Begin by removing the upper and lower plastic panels. Pry the top with a spudger from the corners as shown in the red circle.
    • Remove the SIM card.
    • Next pry off the lower plastic panel. This one is stuck on a little bit more.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Sebastian Edinger
회원 가입일: 05/01/13
517 평판
안내서 1개 작성함
댓글 한 개
An additional more comprehensive wiki troubleshooting guide for the ZTE Max …compiled by a team of students here on “IFIXIT” that I recently discovered that you may also find helpful.
ZTE Max XL Troubleshooting
Jason Thompson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 3,089
