주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZTE Compel Camera Replacement
필요한 것
    1. ZTE Compel Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
      댓글 쓰기
    2. ZTE Compel Camera Replacement: 2 단계, 이미지 1개 중 1개
      • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
      댓글 쓰기
    3. ZTE Compel Camera Replacement: 3 단계, 이미지 1개 중 1개
      • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
      • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
      댓글 쓰기
    1. ZTE Compel Camera Replacement, Camera: 4 단계, 이미지 2개 중 1개 ZTE Compel Camera Replacement, Camera: 4 단계, 이미지 2개 중 2개
      • Remove the 9 screws that measure 4 mm Phillips #000.
      • Use your iFixit Magnetic Project Mat, or any magnetic surface, to hold your removed screws while working on your ZTE Compel.
      댓글 쓰기
    2. ZTE Compel Camera Replacement: 5 단계, 이미지 3개 중 1개 ZTE Compel Camera Replacement: 5 단계, 이미지 3개 중 2개 ZTE Compel Camera Replacement: 5 단계, 이미지 3개 중 3개
      • Notice the crease in the shiny black plastic. Insert the flat end of your spudger here, about 3mm above the volume buttons, and work your spudger around the circumference of the phone until the front and back are separated.
      댓글 쓰기
    3. ZTE Compel Camera Replacement: 6 단계, 이미지 2개 중 1개 ZTE Compel Camera Replacement: 6 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the camera by placing your tweezers on the gold piece attached to camera and lift up, disconnecting from the motherboard.
      • Grip the camera with your tweezers and lift up to remove the camera.
      • May need to use light force to remove camera due to the adhesive on the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Tayler McCleese
회원 가입일: 09/06/18
246 평판
안내서 2개를 작성함
Ohio State, Team S1-G4, Whitney Fall 2018 Ohio State, Team S1-G4, Whitney Fall 2018 회원
OSU-WHITNEY-F18S1G4
2 회원들
안내서 45개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 29
전체 시간: 517
